oil cooler
  • Rocky
  • Rocky's Avatar Topic Author
oil cooler
03 Apr 2014 18:23
#627743
Hi everyone when you install an oil cooler to a kz900 do i have to add extra oil to the engine or does it take the same amount of oil after an oil change? thanks.
  • kaw-a-holic
  • kaw-a-holic's Avatar
Re: oil cooler
03 Apr 2014 19:23
#627748
you will have to add extra oil. How much is to be determined. The lines and the cooler hold extra oil the length ID of lines and the size of the cooler will vary. I would suggest filling it normal, running it for 10-15 seconds and shutting it down. Hold the bike level (not on the center stand) and add until the site glass is at the correct level.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
The following user(s) said Thank You: Rocky
  • dejavoodo41
  • dejavoodo41's Avatar
Re: oil cooler
03 Apr 2014 19:29 - 03 Apr 2014 19:30
#627751
After I put my oil cooler on mine took about a extra 1/2 qt.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Last edit: 03 Apr 2014 19:30 by dejavoodo41.
  • racer54
  • racer54's Avatar
Re: oil cooler
03 Apr 2014 20:50
#627760
Same here....after installing my oil cooler, I ended up with right about 1/2 quart more oil.
