Parts needed, advice wanted
  • jsnabbs
  • jsnabbs's Avatar Topic Author
  • 1981 kawiKZ440
02 Apr 2014 13:47
#627558
No eBay APP ID and/or Cert ID defined in Kunena configurationI just got off the phone with the guy who is recondtioning my motor, I need to find some parts as he cant get them from kawasaki germany.
I need
Cam
Cam chain
cam guides front/back
If im searching these parts as KZ440 when i order and they turn up, am i going to have the right part? or is there something i need to look out for
would like to find these parts in europe if i can so i dont have to wait so long for them and i dont have to pay import tax
one link i found for the guides and chain
is there aftermarket parts i should look at that will work and are new?
Also here is a pic of the gasket set i just ordered, am i missing anything, for a motor rebuild?
Attachment Screenshot2014-04-02at10.45.03PM.png not found
thanks in advance
TIME TO TRADE IN THE PEDALS FOR SOME POWER
  • jsnabbs
  • 1981 kawiKZ440
Re: Parts needed, advice wanted
02 Apr 2014 13:50
#627560
My bike is a KZ440C
But im sure its a KZ440A motor in it, just want to make sure i dont end up ordering parts that dont fit
  • martin_csr
  • martin_csr's Avatar
02 Apr 2014 14:46
#627568
I don't think there was a 440-C in the USA, but it probably shares the same needed parts as most of the 440s (if not all of them). There probably aren't any aftermarket parts, other than gaskets & maintenance stuff. For new you might find NOS parts on eebbaayy. Try using the diagrams at Kawasaki.com & Partzilla. The Kaw site cross-reference is more accurate & Partzilla lists prices for stuff that's still available.
From Kawasaki.com: 12044-5001 CAMSHAFT,VALVE (Cancelled)
Model (16):
KZ400-B1 (1978)
KZ400-B2 (1979)
KZ400-C1 (1978)
KZ400-H1 (1979)
KZ440-A1 (LTD) (1980)
KZ440-A2 (LTD) (1981)
KZ440-A3 (LTD) (1982)
KZ440-A4 (LTD) (1983)
KZ440-B1 (1980)
KZ440-B2 (1981)
KZ440-D1 (LTD Belt) (1980)
KZ440-D2 (LTD Belt) (1981)
KZ440-D3 (LTD Belt) (1981)
KZ440-D4 (LTD Belt) (1982)
KZ440-D5 (LTD Belt) (1983)
KZ440-G1 (1982)
  • jsnabbs
  • 1981 kawiKZ440
04 Apr 2014 00:48
#627776
No eBay APP ID and/or Cert ID defined in Kunena configurationaftermarket cam chain i found, thoughts?
  • Nebr_Rex
  • Nebr_Rex's Avatar
04 Apr 2014 03:02
#627778
jsnabbs wrote: aftermarket cam chain i found, thoughts?
Package of 10 master links. Not a compile the chain.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Nebr_Rex
  • Nebr_Rex's Avatar
04 Apr 2014 03:17
#627780
Cam parts will only be found used unless you can find some nos ( new old stock ) that has been setting
around for years. Gaskets set is complete but you will need some o rings and a output shaft seal. Those
o rings are between the case halves and seal the oiling system.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
The following user(s) said Thank You: jsnabbs
  • jsnabbs
  • 1981 kawiKZ440
07 Apr 2014 14:41
#628239
I found all NOS parts so far
cam guide front & back
cam shaft
i just need a cam chain, anyone have any ideas? is there an aftermarket that fits?
07 Apr 2014 15:22
#628248
  • kaw-a-holic
  • kaw-a-holic's Avatar
07 Apr 2014 17:50
#628263
+1 for Z1
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • jsnabbs
  • 1981 kawiKZ440
08 Apr 2014 10:53
#628337
Thanks for the help guys, i have all the parts now B)
