Problem with camshaft installation, KZ1000R
  • PetterA
  • PetterA's Avatar Topic Author
Re: Problem with camshaft installation, KZ1000R
07 Apr 2014 12:26
#628203
The wires were correct, but after a quick look at the carbs it started!...
...But still with the original problem. It only goes slooooowly back to idle when revved. The engine is fine with all new gaskets etc, also new intake boots and I have ultrasonically cleaned the carbs a few times. And by now I really don´t know what can be the problem..?
I have a Dyna S Ignition and new Dyna coils, but not installed. Can those help?
-83 Z1000 Eddie Lawson Replica
-71 H1 Mach III
  • LarryC
  • LarryC's Avatar
07 Apr 2014 12:47
#628207
Vacuum leak or hanging timing advancer could cause that condition.
Larry C.
  • PetterA
07 Apr 2014 13:40
#628220
LarryC wrote: Vacuum leak or hanging timing advancer could cause that condition.
I have checked for leakage, but since the intake manifolds are new and I have had them checked aswell from where else can it leak?
I have also taken the timing advancer apart and it seems to be working fine from what I can tell..
-71 H1 Mach III
  • LarryC
  • LarryC's Avatar
07 Apr 2014 17:28
#628260
What carburetors are they? Stock CV units or what?
A can of WD40 will find a vacuum leak in a nano second.
Larry C.
  • PetterA
08 Apr 2014 00:13
#628288
LarryC wrote: What carburetors are they? Stock CV units or what?
I´m running with RS34, with the mixture screw 1,5 turns out. I have tried to fint the leak before with starter fluid and have tried different positions on the mixture screw, but I can´t say that I have found anything..
-71 H1 Mach III
  • kz1100warrior
  • kz1100warrior's Avatar
08 Apr 2014 01:39
#628292
Did you check valve clearance, if the valves dont have enough clearance it takes the valves longer to idle down, i have had that same problem, are u running stock airbox or filters. but i guess it is to tight valves.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
08 Apr 2014 03:46 - 08 Apr 2014 03:46
#628300
:laugh: :laugh: :laugh: and make sure you are in a well ventilated area when you spray the WD40
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 08 Apr 2014 03:46 by Mcdroid.
  • LarryC
  • LarryC's Avatar
08 Apr 2014 04:08
#628302
For starters that IMO is way too much fuel on the pilot fuel screw. Close them up and start at 1/8 to 1/4 turn. A little bit is lot on those carbs.
Without looking at the bike it's all just a guessing game Peter. Do you have a push/pull on it? Might just be sticking cable causing it.
Larry C.
