starter
- akiyama 640
starter
01 Apr 2014 17:24
i have a 1984 zn 700 starter worked when cold after engine heats up starter would be slow. now starter does not work.solinoid is working fine i even tried a jumper wire to the starter with no luck. removed the starter and jumped the starter with a battery charger it works but is a little noisy so is my starter bad or do i have a differant problem ive only had the bike a few weeks s i dont know its history
- nickleo373
Re: starter
01 Apr 2014 18:04
Did you check the condition of your battery?
1981 KZ550C LTD
"If you ain't first, you're last"
- Irish Yobbo
Re: starter
02 Apr 2014 04:25
Can you turn the gear on the starter by hand? If it's anything like any starter on a car (I'm still a bit of a noob when it comes to motorbikes) it will spin freely with little noise.
Did you try jump starting the motorbike? If you can jump the motorbike, it's a battery or connection problem. Check you earth cable is in good nick and has a clean connection (and make sure that it's actually to the earth - the first thing I had to do on my bike is re-attach the earth, because the previous owner had bolted it to the battery box which is not earthed to the rest of the bike.).
1981 KZ750 LTD
- akiyama 640
Re: starter
02 Apr 2014 15:12
checked battery first,i watched some videos on you tube on starters and i am pretty sure it is the starter. when i put power to the starter it just spun it did not jump off the floor like in the vids i watched. i am ordering a rebuild kit from RICKS ELECTRICS only 40.00 bucks
