KZ750 CSR: No start and backfiring
- bpchura
- 1982 KZ750 CSR
So, the problem is that the bike WILL NOT START. Its a 1982 KZ750 CSR twin. Its got electronic ignition as standard and it seems to be working fine. I have checked spark and its a decent blue one on both sides. Advancer is lubed and installed correctly. Compression is stong (160 lbs both sides) and valves have recently been adjusted to spec. I have ridden with the new valve job so that does not seem to be an issue. CARBS. Boots are fine and dont seem to be leaking. Bench synched and very clean. Float level set and not leaking. Everything SEEMS to be perfectly fine.
When I try to start, I get a really good crank but backfiring through the exhaust. Plugs are WET with fuel. No work was done with the cams so timing should still be set and good to go. And thats it. Nothing else. Im just stuck with a non running, seems-to-be-fine sort of deal.
What do you think could be the issue. I am sure I left some things out so feel free to ask. Thanks
The first motorcycle race began when the second motorcycle was built. - Anonymous
- bountyhunter
- Thank you received: 337
Check fuel levels with a clear tube.bpchura wrote: Hello everyone. Its spring now and everything that has gone wrong (which is a lot) has been corrected as far as I know and I need to get out and RIDE! Hopefully you guys and help me figure out whats going on.
- bountyhunter
I would still suspect the advancer or maybe that the timing is off. My 750 twin doesn't have elect ignition so I am not an expert on that.bpchura wrote: . Its a 1982 KZ750 CSR twin. Its got electronic ignition as standard and it seems to be working fine. I have checked spark and its a decent blue one on both sides. Advancer is lubed and installed correctly.
- bountyhunter
Shooting from the hip here: make sure the plug is not wet with fuel and OIL. These twins do have the valve seals go bad and the oil can run down from the valve shaft through the opening and onto the plug (guess how I learned about that).Plugs are WET with fuel.
It fouls the plug which on a twin means NEITHER plug can fire (they are wired in series) so they don't fire and the cylinders flood with gas.
Sometimes the plug would clear and you hear a loud POP backfire but it doesn't start. Made mine and absolute beech to try to start, constantly fouled plugs.
Something to check.
- bpchura
- 1982 KZ750 CSR
- bpchura
- 1982 KZ750 CSR
- bountyhunter
Measuring the mechanical gap won't work. Not sure what carbs yours has: on the BS-38, the fuel level is supposed to be 4.5mm down from the lower edge of the carb's upper.bpchura wrote: Levels are good. About a half inch below the carb body. Measured the gap also on the float. 18mm
- bpchura
- 1982 KZ750 CSR
- Thank you received: 2098
- bpchura
- 1982 KZ750 CSR
- bpchura
- 1982 KZ750 CSR
- bountyhunter
Same thing I did, gave me a nice batch of misery. Z1 sells a good replacement coil for $36.bpchura wrote: I changed out the coil with one I got online from a salvage shop.
I don't under stand this:
It couldn't be too far off. I just changed it less than a mm. Would that cause it to flood immediately?
Are you checking with a clear tube to actually read the fuel level or just measuring the float> If not using clear tube, it could be way off. On my BS-38, the spec is 5.5mm +/- 1mm so a 1 mm change is a big deal.
Are you saying that you are seeing flooding?
If so, it will never start.
