492 crankshaft rods
- toad
492 crankshaft rods
30 Mar 2014 04:05
I have recently purchased a z1 bottom end that was being built for a dragbike and I was told the crank was a mk2.It has a 16 tooth center with a 25mm crank end as well the rods are marked 492 and have been polished and take a 17mm pin.Does anyone know anything about 492 rods?
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- toad
Re: 492 crankshaft rods
31 Mar 2014 14:04
Anyone?
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- 4TheKZ1000
- Dr. Gamma
31 Mar 2014 16:34
I was thinking the same thing as 4TheKZ1000.
49200 is late model GS1100E parts!!!
1986 RG500G 2 stroke terror.
- 4TheKZ1000
31 Mar 2014 16:49 - 31 Mar 2014 16:55
Larry could tell you about them.
You could call the guy who likely built the crank, John Pearson. This guy is to motorcycle cranks as George Barris is to hotrods.
Any numbers stamped to identify it?
Last edit: 31 Mar 2014 16:55 by 4TheKZ1000.
- toad
31 Mar 2014 17:41
I cannot find any other numbers except 492 10.Would the length be the same as kz.
thanks for the info
thanks for the info
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
