Backfiring
  • hotdogg
  • hotdogg's Avatar Topic Author
  • 1982 kz750 spectre
Backfiring
27 Mar 2014 14:21
#626799
Can someone enlighten me on some reasons a bike would backfire. Thank you
1982 kz750 spectre
Re: Backfiring
27 Mar 2014 15:04
#626810
One possible reason could be a too tight intake valve causing backfire through the carb.
Good Fortune! :)
  • gpz1170
  • gpz1170's Avatar
Re: Backfiring
28 Mar 2014 10:09
#626899
air leak at the carbs
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
  • baldy110
  • baldy110's Avatar
Re: Backfiring
28 Mar 2014 11:10 - 28 Mar 2014 11:12
#626902
If it started after installing a 4 into 1 pipe or pod filters it's usually a lean mixture install one size larger pilot. jets. If it started without any mods being done then I would look at air leaks at manifolds or the pilot system is getting dirty.
Last edit: 28 Mar 2014 11:12 by baldy110.
  • bountyhunter
  • bountyhunter's Avatar
Re: Backfiring
28 Mar 2014 16:51
#626932
Lean condition or timing advancer problem.
The following user(s) said Thank You: hotdogg
  • loudhvx
  • loudhvx's Avatar
Re: Backfiring
29 Mar 2014 15:48
#627021
Bikes with the air suction system will backfire big and loud when you close the throttle if the system is malfunctioning, which is very common.
The easy remedy is to remove the system and cap off all ports.
  • hotdogg
Re: Backfiring
15 Sep 2014 19:54
#647710
It was the advancer thank you I would have never thought of that
1982 kz750 spectre
