Liska Cam Chain Sprockets
- Zedone
27 Mar 2014 07:39
Hi guys,
Is anyone here running Liska aftermarket cam chain idler sprockets? My stock sprockets are in need of replacement and wanted some feedback. They are less $ than the oem but still very pricey. I like the fact there is no rubber to wear out on them.
Thanks, Doug
Thanks, Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
Re: Liska Cam Chain Sprockets
27 Mar 2014 08:05
Im running them and have no problems
- gpz1170
27 Mar 2014 09:58
They are great but maybe a little noiser than OEM. Happy with mine
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- racer54
28 Mar 2014 11:25
I read somewhere that you have to run some slack in the cam chain when you run these solid sprockets. If that's so, how to you go about doing that? I believe it was about 1/8" slack at the sprocket but I could be wrong. Do you guys running these sprockets run the cam chain with some slack or just adjust cam chain tension same as stock?
28 Mar 2014 12:01racer54 wrote: I read somewhere that you have to run some slack in the cam chain when you run these solid sprockets. If that's so, how to you go about doing that? I believe it was about 1/8" slack at the sprocket but I could be wrong. Do you guys running these sprockets run the cam chain with some slack or just adjust cam chain tension same as stock?
Stock.
I honestly hadn't heard about adding in some extra slack
- zed1015
28 Mar 2014 12:04
I run solid sprockets.
I make my own by replacing the old rubber centre with solid alloy ( cheaper and just the same as using Liska etc
I run them adjusted just the same as std ones.
Best way is to rock the crank with a spanner whilst lightly taking up the slack on a manual tensioner by hand (no spanner).
You can feel when the slack is taken up .
On a rebuilt motor with new chain etc I run it up to let everything settle and re-check.
Hardly ever needs re-doing after that.
- racer54
30 Mar 2014 20:53
OK...thanks....just something you should know about before doing it wrong and costing a motor....
- Zedone
31 Mar 2014 12:53
Thanks for all your replies guys!
1977 KZ1000A1
- hondaseven
16 Apr 2017 04:16
When you say a little noiser does it make a rattly sound or a whirring noise
16 Apr 2017 05:27
I like the whirring sound they make.
- zed1015
16 Apr 2017 05:57
Three year old thread brought back from the dead.
