kz900 clutch rod
- Handcannon
kz900 clutch rod
24 Mar 2014 12:21
Should you grease the point where the clutch rod fits into the part the clutch cable pulls on to push the rod in?
- JimB
Re: kz900 clutch rod
24 Mar 2014 12:43
Yes you can grease that end piece of the rod,... but it is more important grease the entire length of the rod that goes into the engine and pushes the clutch plates.
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
- koolaid_kid
24 Mar 2014 14:12
It is most important to remove the worm gear from the sprocket cover, unscrew it, clean it and grease it. It catches all the gunk from your sprocket area and can make the clutch operation temperamental, at best.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- LarryC
24 Mar 2014 17:25koolaid_kid wrote: It is most important to remove the worm gear from the sprocket cover, unscrew it, clean it and grease it. It catches all the gunk from your sprocket area and can make the clutch operation temperamental, at best.
$20 says I know what the next question to be posted to this thread is :silly:
Larry C.
- Handcannon
- LarryC
25 Mar 2014 03:25Handcannon wrote: Ok what kind of grease? Was that the question?
Not that one
Larry C.
- pete greek1
25 Mar 2014 08:06
Looks like Larrys out $20.00 ...LOL :lol: :lol:
- koolaid_kid
25 Mar 2014 08:20
LOL. Perhaps he can buy us all a beer. PBRB, anyone?
Actually, I suspect the OP missed my point, but IDK.
1983 GPz 750
