Kz 750 b4 camshaft
- handyman1
Kz 750 b4 camshaft
22 Mar 2014 22:34
Hi im starting to rebuild my engine after completely stripping and blasting. Do the cam shaft bearings need to be replaced? They look ok but im no expert.
Also do you know how to find markings on the conrod and crankshaft to determine what bearing colour i need to replace these as there is some play at the big end.
Any help would be greatfully recieved.
- handyman1
Re: Kz 750 b4 camshaft
22 Mar 2014 22:40
- steell
22 Mar 2014 23:29
There are no cam bearings, the cam journals ride directly on the aluminum head.
If you don't have a manual, there are a few available for download, and it will tell you what colors and how they are identified. Measure, measure, measure, and measure again.
- handyman1
23 Mar 2014 01:31
Hey sorry if ive waisted anyones time but I actually meant . So if anyone can help with crankshaft setup that would be awesome.
23 Mar 2014 06:24
You might want to check the bearing clearance with plastigauge before replacing anything. May not need it.
- handyman1
23 Mar 2014 12:26
Thanks for that. Ive read about plastiguage in the manual but how do use it? And where can i get it?
- bountyhunter
23 Mar 2014 16:05 - 23 Mar 2014 16:06Kragens or Auto Zone or any car parts place.handyman1 wrote: Thanks for that. Ive read about plastiguage in the manual but how do use it? And where can i get it?
You put the gauge in under the bearing cap and torque down then remove bearing cap and compare width of gauge strip to chart. It tells you the clearance.
Last edit: 23 Mar 2014 16:06 by bountyhunter.
