1976 KZ 750 B - tachometer cable
  • Clabedan
  • Clabedan's Avatar Topic Author
  • 1976 KZ 750 B
21 Mar 2014 11:55 - 21 Mar 2014 11:56
#626038
Hi
Just ordered a tachometer cable as a replacement for my old one. The replacement part is mentioned as compatible with KZ 750 B (part 54018-24) but is too big to fit inside the engine side (tachometer side is OK).
I have searched on the web but they all seem to be similar. Does anyone know the right part number for this? My KZ is a european version and I have attached a picture of old and new cables. It's not obvious but as you can see, the one on top is larger than the original one.
Many thanks for your help. ;) ;) ;)
Attachment tachometercables.jpg not found
Christophe
1976 KZ 750 B soon to be street tracked
Last edit: 21 Mar 2014 11:56 by Clabedan.
  • bountyhunter
  • bountyhunter's Avatar
Re: 1976 KZ 750 B - tachometer cable
21 Mar 2014 12:28
#626041
I have the 79 KZ750B and I know I did buy a new tach cable a few years back that did fit. Can't remember the place. Not sure how or why the European version would be different? Maybe somebody else has experience with the euro versions mine is US.
  • koolaid_kid
  • koolaid_kid's Avatar
21 Mar 2014 14:12
#626056
The one on top is clearly slightly larger in diameter.
I'd contact Z1Enterprises and see if they can order you the correct one.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
21 Mar 2014 17:56
#626088
Clabedan wrote: ...tachometer cable as a replacement for my old one. The replacement part is mentioned as compatible with KZ 750 B (part 54018-24) but is too big to fit inside the engine side (tachometer side is OK)....
Could double-check the part number, as kawasaki.com shows 54018-021.
Good Fortune! :)
The following user(s) said Thank You: Clabedan
  • steell
  • steell's Avatar
22 Mar 2014 23:37 - 22 Mar 2014 23:41
#626191
According to kawasaki.com, 54018-024 fits the following models:
KL250-A1 (KLR250) (1978)
KL250-A1A (KLR250) (1978)
KL250-A2 (KLR250) (1979)
KZ200-A1 (1978)
KZ200-A1A (1978)
KZ200-A2 (1979)
KZ250-D1 (KZ250) (1980)
KZ250-D2 (CSR) (1981)
KZ250-L1 (CSR Belt) (1982)
KZ250-W1 (LTD Belt) (1983)
So I'd say you have the wrong cable, you need the 54018-021
Parts Unlimited has one listed on eBay for $12.95 shipped to the US.
eBay Link
Last edit: 22 Mar 2014 23:41 by steell.
