16 tooth crankshaft
- toad
16 tooth crankshaft
18 Mar 2014 20:47
I am trying to distinguish which crank I have in this bottom end.I know it has 16 tooth centre and no woodruf key on the end,but its in z1 cases.I suppose my question would be what are the differences between a J crank and a Mach 11 crank?
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- zed1015
Re: 16 tooth crankshaft
19 Mar 2014 02:10
If it's 16t and takes a roller chain it's a mk2 crank.
They drop straight in to all kickstart cases with the matching cam sprockets and is a popular upgrade.
The 'J' crank is easily identified as it takes a hyvo (silent type) camchain .
- toad
19 Mar 2014 04:38 - 19 Mar 2014 05:10
Are the rods the same length as well or do I need to use a spacer to correct.I will be looking for the proper top end for a dragbike build,thanks for the info
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Last edit: 19 Mar 2014 05:10 by toad.
- zed1015
19 Mar 2014 05:23
Yes! The MK2 rods are the same so no spacer needed for that reason.
It is the 'J' onwards rods that are shorter.
- toad
19 Mar 2014 05:48
how about the stator cover will that have to be swapped out for a 79-80 model?thanks
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- zed1015
19 Mar 2014 09:10
Yes! the MK2 alt is different and needs the matching cover to mount the stator coil.
The following user(s) said Thank You: toad
