Bike will not fire
- FloridaZ1A
Bike will not fire
18 Mar 2014 18:25
Hey guys I'm new to the site and figured this was the best place to get information. I have a late 1973 z1a that will not start. Bike ran well before I had to replace a broken head stud that broke off in the lower case. I rebuilt the motor and now the bike simply won't start. I've done everything to spec as far as the cams and the cam chain and rebuilt the carbs to insure fuel is there. I have good spark on all 4 plugs but am unsure if my timing is correct on the ignition or if I have a compression issue due to a shim problem. The starter seems to be running somewhat fast and even with spraying fuel into the carbs there is no combustion other then the occasional pop. Any an all help would be greatly appreciated.
- KZJOE900
- Administrator
Super Users
Re: Bike will not fire
18 Mar 2014 19:02
Might try doing a compression test.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- FloridaZ1A
18 Mar 2014 19:09
Yeah that was going to be my next action. Do you know off hand what I should be getting on each cylinder?
- toad
19 Mar 2014 04:51
I would check your advance as well, make sure its on their right ,double check shims,wires ,12v too coils.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- FloridaZ1A
19 Mar 2014 08:02
There was practically zero compression. It bearly moved the gauge. I bought two different gauges thinking the first was reading wrong. It read approximately 15 psi on all cylinders. I'll take pictures tonight and hopefully a keen eye can spot what's wrong
- koolaid_kid
19 Mar 2014 08:53
DID you have the throttle fully open when you ran the tests?
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- FloridaZ1A
19 Mar 2014 08:57
Yes I tried it with all sparkplugs in and with them all out like I should. Tried it with the choke fully on and with it off and with the throttle full open and closed with bearly any movement on two different gauges.i turned the motor over for 8 rotations on each try.
- kawman66
20 Mar 2014 21:22
you are cranking with starter right.
75 z1b
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
my drinking team has a racing problem
76 kz900ltd
76 kz900
76 kz900-1500
77 kz1000ltd
- FloridaZ1A
20 Mar 2014 21:29
Yeah after checking the shim clearance they are way off over all valves. I'm going to get them within .002-.004 tolerance and try again
