Big favor: Bolt dimensions on '82 550 tensioner
- Dresgeve
15 Mar 2014 14:41
Here's the deal, my '82 KZ550 LTD was having issues starting, finally suspected timing and took it apart to re-time it. I was literally 30 minutes from being done... As I was putting the tensioner back in though, the bottom bolt head spun off... Luckily there's still bolt showing, so I should be able to get it back out easily. Anyway, it was really late that night, so I packed it up and went home (I live about 35 minutes from my place to work). School took over, but I may actually be able to go out late tonight and try to finish it up! Only thing is, I need the bolt dimensions. I'd just go grab the second bolt from the garage, but by the time I can head out there, it'll take too long to drive back and stores will be closed, so I need to go out with parts in hand if possible. So does anyone have those dimensions available? I'd greatly appreciate it! I'm dying to get this thing back on the road! It's my place to think
Just to avoid any confusion, I need the two bolts on here: (I know everyone knows what a tensioner is... Still, might as well clarify just to play it safe
Thanks!
Thanks!
Re: Big favor: Bolt dimensions on '82 550 tensioner
15 Mar 2014 15:52
According to Kawasaki.com the bolts are 6x25mm (see image below). I HIGHLY recommend you use an appropriate torque wrench (INCH pounds) and the torque specs in the manual so you don't damage the cylinder head. Otherwise big bucks will be needed to fix the problem. Ed
Attachment 00007_2014-03-15-2.jpg not found
- Dresgeve
15 Mar 2014 16:16
Ah, that should do it, thanks! I didn't even think about that site for some reason. Yeah, I am using a torque wrench where necessary, but amazingly this broke off before it even reached the engine wall. There wasn't any major torque needed yet, but somehow it spun off. I guess it just reached it's limit. I've never seen a bolt break that easily though without major corrosion.
- loudhvx
16 Mar 2014 08:51 - 16 Mar 2014 08:52
Read the valve train warning in my signature if you haven't already. You have to remove the tensioner cross wedge before installing the tensioner and/or valve cover.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 16 Mar 2014 08:52 by loudhvx.
