jet suggestions
  • jonarmstrong
  • jonarmstrong's Avatar Topic Author
jet suggestions
15 Mar 2014 07:50 - 15 Mar 2014 07:52
#625260
I'm sure this has been covered before and jetting is a little bit trial-n-error but I'm lookikg for a bench mark to go from in tuning my carbs. I'm changing a few things and I believe I'm running a little rich on bottom already. I have been running a homemade 4-1 and pods on a basically stock bike. Here's where the changes come in. Just bought a kerker 4-1 w kerker can, stock airbox w k&n, dyna coils and wires, carb and airbox boots, and just recently put 81gpz1100 cams in. I believe I'm running 40s and 125s in my bs34s now w the needle shimmed almost 1/16 in w washers. Any suggestions? Oh, and I live in the mountains so I change elevation from 1000-3000 ft on the regular!
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
Last edit: 15 Mar 2014 07:52 by jonarmstrong. Reason: more info
  • jonarmstrong
Re: jet suggestions
16 Mar 2014 06:55
#625379
Larry C, any suggestions?!
  • toad
  • toad's Avatar
Re: jet suggestions
17 Mar 2014 05:02
#625515
when I had those carbs I remember using 40 / 140.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
The following user(s) said Thank You: jonarmstrong
