oil leak in ignition points
- happyhunter
12 Mar 2014 14:59 - 12 Mar 2014 15:00
I have a leak in my 82 305 CSR which causes oil to run down from the left side top cover. The ignition points are behind this cover. I replaced the points a few months back and noted the gasket under the cover was torn. I just left it out and put the cover back on.
Is it normal for oil to be in that part of the engine? I do not see a way for it to get back to the bottom end. If I put a new gasket under the cover will I have bigger probs when the points are swimming in oil. I am thinking it may need a cam seal of some sort???? Maybe I am thinking too much??
I am loving this warmer weather here in PA. Made it to about 60 yesterday. I am approaching 100 miles on my first bike!!!!
Thanks,
HH
Thanks,
HH
'82 Kawasaki KZ305CSR
I did not set out to buy a project bike,
but I got one anyway.
Last edit: 12 Mar 2014 15:00 by happyhunter.
- JR
Re: oil leak in ignition points
12 Mar 2014 17:39 - 12 Mar 2014 17:46
Hi
I'm not familiar with the 305 but kawasaki.com owner info, parts diagrams etc shows an oil seal for that end of the camshaft. Clicking on the part # it says the part is still active so you should be able to order from any Kawasaki dealer. It world probably be a good idea to replace it. Shouldn't be to difficult and a manual would be a big help in putting everything back together and avoiding incorrect assembly and bent valves.
I didn't check on the points cover or cylinder cover gaskets but if they are not available you could try cutting your own from gasket paper.
Oil is a good insulator so I think that if it gets on the points then they would not function properly
Good luck
Good luck
Last edit: 12 Mar 2014 17:46 by JR.
