KZ650/GPZ750 header question
- chrisjames
11 Mar 2014 14:52
I have a 1981 CSR KZ650 that ive done a motor swap on with a 1984 GPZ750. Ive read that i can run a kz650 header on a kz750/gpz750 but my question is can i run a newer ninja 600 header on it or no??? Im looking to switch to a 4 into 1 and was wondering if the older ninja 600 would fit since i work next to a salvage that has some used 4 into 1 off some older bikes. Thanks
- StreetfighterKz
Re: KZ650/GPZ750 header question
11 Mar 2014 16:19
I don't have a definite answer but I'm going to guess anything 1983 and newer will not be a direct bolt one except the 750 Zephyr and the early 2000's Zr750. Most modern water-cooler sport bikes switched to a side oriented cam drive so the inner two cylinders will be closer together unlike the KZ's that have a central cam chain and have the inner two cylinders spread apart..
However, you may get something close and make it fit though.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
