dowel pin
- rosken
dowel pin
09 Mar 2014 06:03
Hi everyone, I started rebuilding a z750ltd engine (after converting it to kick start) to put into my z650, however I have a 19mm dowel pin and I don't know where it goes, it is not for the side caseings and its not for where the crank caseings join , does anyone know where it goes? it doesn't seem to give any info in the manual . I would be happy if someone has the answer,
thanks.
thanks.
Re: dowel pin
09 Mar 2014 06:29rosken wrote: Hi everyone, I started rebuilding a z750ltd engine (after converting it to kick start) to put into my z650, however I have a 19mm dowel pin and I don't know where it goes, it is not for the side caseings and its not for where the crank caseings join , does anyone know where it goes? it doesn't seem to give any info in the manual . I would be happy if someone has the answer,
thanks.
Perhaps the dowel pin would show in a parts diagram at kawasaki.com.
Lots of good info on kawasaki.com, including parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
www.kzrider.com/forum/13-bike-related/37...imitstart=0&start=20
- 4TheKZ1000
Re: dowel pin
09 Mar 2014 06:31 - 09 Mar 2014 06:43
A dowel pin that size might be the dowel located at the cylinder?
www.z1enterprises.com/ItemDetails.aspx?i...1000&item=92043-1266
www.cmsnl.com/kawasaki-1980-kz750-h1-ltd...11x14x123_920431266/
Attachment Z1E_4524.jpg not found
Last edit: 09 Mar 2014 06:43 by 4TheKZ1000.
- rosken
Re: dowel pin
09 Mar 2014 07:34
god yes, its so obvious now, cant believe I never realised where it went, silly me,
thanks guys, great!
thanks guys, great!
The following user(s) said Thank You: 4TheKZ1000
