Kz750 part numbers
  • Schmeck
  • Schmeck's Avatar Topic Author
Kz750 part numbers
08 Mar 2014 07:16
#624502
Can anyone tell me the part number for the gear shift oil seal that's on the inside of the engine cover. I can't seem to find it . It's the seal that the shift lever shaft goes into just to the right of the sprocket . Mine is leaking oil and I need to get the replacement seal before the engine gets put back in .
I can post a picture if it would help.
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
  • lowie182
  • lowie182's Avatar
Re: Kz750 part numbers
08 Mar 2014 08:34
#624509
1981 KZ550 C2 parts bike (2010-Present)
1981 KZ550 C2 rental/back-up bike (2010-Present)
1981 KZ750 H2 Daily Driver (2012-Present)
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
08 Mar 2014 09:28
#624515
According to the Kaw web site the part# for the seal(on inside of cover) is 92051-005 (OIL SEAL,TB13225.5 ) and is listed as an active part. There is also a gasket on the outside of the cover - part# 14046-033 (GASKET,R.H ENGINE COV) which is listed as no longer actibve.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Schmeck
08 Mar 2014 15:16
#624548
Thank guys. Will finally seal that pesky leak .
  • steell
  • steell's Avatar
09 Mar 2014 23:34 - 09 Mar 2014 23:41
#624686
Used on the shifter shaft on: KZ1300, KZ305, KZ400, KZ440, KZ550, KZ650, KZ700, KZ750 (fours), ZN1300, ZN700, ZX550, ZX600, ZX750, ZX900B/C
I believe the original poster is looking for a seal for a "750 twin", not a 750 four.
EDIT:
In spite of the Z1 Enterprises description, according to kawasaki.com parts diagrams, that same seal fits the 750 twin (and a ton of other bikes).
Last edit: 09 Mar 2014 23:41 by steell.
