Counter sprocket nut.... Too small
- Clabedan
- 1976 KZ 750 B
07 Mar 2014 11:01 - 07 Mar 2014 11:01
After losing my front sprocket nut on my KZ 750 B (1976 model) and further to you guys advice, i ordered a new one with the good washer from z1 enterprises:
www.z1enterprises.com/ItemDetails.aspx?i...KZ750&item=92015-019
2 weeks later, the parcel arrived and guess what, the nut is too small... Not by much but i cańt even get it on!
The reference says it fits KZ 750b
Now have i ordered the wrong part?? My kz is a european model but I cańt believe this would affect the nut size.
If anyone can enlighten me, I would be extremely grateful because I dońt even know what to order as a replacement :woohoo:
and the bike is stuck for at least another two or three weeks
1976 KZ 750 B soon to be street tracked
Last edit: 07 Mar 2014 11:01 by Clabedan.
Re: Counter sprocket nut.... Too small
07 Mar 2014 13:06Clabedan wrote: After losing my front sprocket nut on my KZ 750 B (1976 model) and further to you guys advice, i ordered a new one with the good washer from z1 enterprises:
If anyone can enlighten me, I would be extremely grateful because I dońt even know what to order as a replacement :woohoo:and the bike is stuck for at least another two or three weeks
The 20mm nut is probably needed instead of the 18mm nut.
www.z1enterprises.com/ItemDetails.aspx?i...KZ650&item=92016-028
2 weeks? :ohmy:
From Z1, it's usually 2 days.
07 Mar 2014 14:12 - 07 Mar 2014 14:20
It looks like Z1E goofed (pretty rare). According to Kawasaki.com, the 1976 KZ750-B1 through the 1979 KZ750-B4 all use a 20mm nut, not the 18mm nut shown in your link. In fact, it shows ALL the KZ750 models (2 or 4 cylinders), KZ650 models, ZX750, KZ700, etc. using a 20mm nut. Oooops, time for Z1E to re-do that parts description.
Patton, the shipping time is probably long because the OP is in Paris, France. I'm surprised the part is not available locally. Ed
Attachment 00007_2014-03-07.jpg not found
Last edit: 07 Mar 2014 14:20 by 650ed.
- loudhvx
07 Mar 2014 15:08 - 07 Mar 2014 15:28
The problem is that the Kawasaki cross reference is not infact a cross reference. It is simply a list of bikes whose parts fiche contains that number anywhere. It does not mean that part is used in the same place, and it does not even mean the part is actually used on the bike. It just means the bike's fiche has that number listed somewhere.
It is common for a fiche to list when a part is used on a different year, but not the year of the fiche itself.
In this particular case, it is such a generic part, it shows up on almost any kawasaki from that era.
As Ed said, Z1 Enterprises will have to revise that listing. It lists that part as the sprocket nut for the KZ550 family of motors, but that family of motors doesn't even use a sprocket nut. They use a clip.
They do, however, use that same nut for the starter clutch inside the transmission, which is why it appears on the cross reference, in this case.
As Ed and Patton said, the 1976 Kz750B1 uses a 20mm sprocket nut, part number 92016-043. Same part is used on the KZ900 and a few others.
Z1Enterprises says that the 92016-043 nut is replaced by the 92016-028 nut. They are both 20mm nuts, but require different size tools to remove them. The details are in the listing. (It also lists the Kz750B as using it.)
I'm sure they will exchange it. They have been really really good about correcting mistakes and are, in my opinion, the best source for KZ parts. Definitely call them. I'm sure they will happily correct the problem. (They might ship it out and not even care about getting the other one back.)
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 07 Mar 2014 15:28 by loudhvx.
- Clabedan
- 1976 KZ 750 B
07 Mar 2014 16:01 - 07 Mar 2014 16:02
2 weeks to Paris france... Not their fault
And yes after doing sole research it looks like i should have ordered 20mm... Damned !!!
thanks guys, at least i now know what to order... Shame, it was a sunny weekend in France
Last edit: 07 Mar 2014 16:02 by Clabedan.
