Pitted Head Gasket
  • Scrubadubbdubb
  • Scrubadubbdubb's Avatar Topic Author
Pitted Head Gasket
04 Mar 2014 15:13
#624170
Alright to the cylinder block off to make measurements and confirm that bottom end was still good. This is what the top surface of it looks like after I have cleaned it all up. I had installed a new head gasket and then found out my head was all jacked so I disassembled and bought a new cylinder head. I'd just like some input on what I can do about the pitting? Any input would be appreciated!
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Pitted Head Gasket
04 Mar 2014 16:25
#624176
Normal nothing to worry about check the block for flatness if it checks ok run it.
1984 750 Turbo
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
04 Mar 2014 16:46
#624180
I agree with DFIGPZ.
I presented the same condition to my machine shop guy when my cylinder was bored, he was not concerned with it.
I ran it and am running it now without issues.
Don't worry about it.
  • Scrubadubbdubb
04 Mar 2014 17:32
#624190
Great that makes me feel a lot better. Here's a second question though. I have bought some spray-a-copper gasket sealant meant to be sprayed onto gaskets and allowed to tack up for extra seal. It's high temp and says specifically for head gaskets, exhaust manifolds, and turbochargers. Should I go ahead and use this on the base gasket and/or head gasket when I reassemble?
  • baldy110
  • baldy110's Avatar
04 Mar 2014 20:09
#624209
Scotch bright pad will clean that up, it is normal.
  • bountyhunter
  • bountyhunter's Avatar
05 Mar 2014 12:47
#624259
Scrubadubbdubb wrote: Great that makes me feel a lot better. Here's a second question though. I have bought some spray-a-copper gasket sealant meant to be sprayed onto gaskets and allowed to tack up for extra seal. It's high temp and says specifically for head gaskets, exhaust manifolds, and turbochargers. Should I go ahead and use this on the base gasket and/or head gasket when I reassemble?
I used a sealer like yamabond or 3-bond on the base gasket to prevent any possibility of oil leaks. Head gaskets usually don't need any sealer.
  • J.Holiday
  • J.Holiday's Avatar
02 Apr 2014 12:12
#627536
Is it better to use a copper spray gasket sealer as mentioned in the OP or could a fellow use black high temp (650F) from AutoZone?
'82 KZ1000 LTD First bike and a WIP
