Finally Heard It Run
- Nebr_Rex
Re: Finally Heard It Run
04 Mar 2014 02:59ChopFinger123 wrote: Im not sure of the carb type. I have a factory service manual for a 1979 KZ1000E-1 Shaft that says they had VM28SS carbs but my bike is a 1980 KZ1000E-2Shaft. Im not sure if they changed the carbs for those year models.
Sent from my SCH-S720C using Tapatalk 2
Only changes between "79 and "80 are cosmetic.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- ChopFinger123
04 Mar 2014 03:20
Good to know my service manual is good for my bike.
I plan to check compression and clean the carbs tomorrow. Hopefully i won't have to pull the valve covers off. There's snow on the ground here and i have to work on the bike in it. So the easier the fix the better. Im tired of the cold lol.
- fastidiots
04 Mar 2014 09:27
First off you said it has pods on it, so yes it most likely IS running lean...too lean to idle.
Second you are having to run it choked to get it to idle, which richens it up and is then causeing it to run too rich.
Cure both problems the easy way by puting a stock airbox back on it or....
the hard way by getting a dyno jet kit and spending LOTS of time playing with the jetting and tuning till you get it to resemble a normal running bike.
82 KZ1000 J
76 KZ750 B1
76 KZ750 B1
- ChopFinger123
04 Mar 2014 16:02
I just got the carb to box boots today in the mail. Actually got them from a member here.
Im a little busy rebuilding the front end on my truck right now but ill get the airbox back in asap. Thanks for all the advice. Ill update when i get it back right.
- ChopFinger123
09 Mar 2014 15:11
So i got the airbox in and its still poppin out carb 1&2. Do you guys think it might be the valves?
- Nebr_Rex
09 Mar 2014 16:28ChopFinger123 wrote: So i got the airbox in and its still poppin out carb 1&2. Do you guys think it might be the valves?
What's your valve clearence.?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- ChopFinger123
09 Mar 2014 16:48
I haven't had a chance to pull the covers but that's not a very hard job to do is it?
09 Mar 2014 18:58ChopFinger123 wrote: So i got the airbox in and its still poppin out carb 1&2. Do you guys think it might be the valves?....
Perhaps insufficient clearance.
- ChopFinger123
13 Mar 2014 02:48
Well i took my carbs apart in the break room at work (don't tell the boss lol) and who woulda thought my pilot jets on 1&2 were completely clogged. I guess when i cleaned them the first time i had too many cold ones in my system and completely over looked that little part.
I still need to get the tank cleaned out and check valve clearance but hopefully the carbs are good now. Im hoping that ill have some new intake boots in the mail when i get off work too. That would be nice.
- ChopFinger123
13 Mar 2014 18:39
I must have really had too many cold ones last time i messed with the bike. I was sitting on it checking the drag bars for fit and noticed i had 1&2 wires mixed up. No wonder it was running on one side and not the other.
With clogged pilots and wires mixed up its amazing it even ran lol.
- ChopFinger123
23 Mar 2014 14:41
I've got the bike running pretty good now just a couple more problems.
The problem is that now i have fuel blowing out the exhaust on the right side. Im assuming that its coming from number 3 because i left the petcock on prime and it was the only one that leaked. I checked spark on it and i have good spark on all cylinders.
How does the fuel go all the way to the exhaust without being burnt with good spark? Could it just be that the float levels are too high?
23 Mar 2014 15:12ChopFinger123 wrote: ... fuel blowing out the exhaust on the right side... good spark on all cylinders.
How does the fuel go all the way to the exhaust without being burnt with good spark? Could it just be that the float levels are too high?....
Would suspect at least one carb is flooding -- perhaps due to a leaking float valve -- and furnishing excessive fuel mixture or raw gasoline into a combustion chamber which excessive fuel is exiting through the exhaust.
At least some, if not all, of the excessive fuel isn't being combusted.
In my experience, partial combustion may result in black exhaust smoke and gasoline odor from the exhaust. However, raw fuel blowing from the exhaust may more likely result from no combustion in one of the cylinders.
Could spray water mist onto the exhaust headers shortly after starting a cold engine, and see which cylinders are combusting (water spray instantly vaporizes and sizzles off an exhaust header from a combusting cylinder).
