Side gapping plugs?
- stilkikin
- Why the **** did I do that?
Side gapping plugs?
02 Mar 2014 08:55
Anyone done it to their KZ? Did it make any difference. I side gapped and indexed plugs on my 351C and the seat of the pants dyno did not tell me much. Would it help these engines any?
82 KZ750L
78 KZ650SR
78 KZ650SR
- bountyhunter
Re: Side gapping plugs?
02 Mar 2014 12:19
I have yet to see any data I believe that indicates rotating the plug gap does anything.
- steell
03 Mar 2014 13:31
Indexing plugs is done when there is only one position where the ground strap on the plug will not hit the piston, it's got nothing to do with power.
Side gapping plugs? If you're totally bored and want to be able to say you did something, or want to brag about it to others without a clue, then go ahead. There is no benefit to side gap plugs in a KZ motor.
- Rampage1967
04 Mar 2014 18:39
Side gapping plugs is simplyaway to deal with tight clearances in the combustion chamber, nothing more.
1978 Kawasaki KZ650 C1??
1974 Honda CB 360
1974 Honda CB 360
- wireman
04 Mar 2014 23:31
The way it was explained to me as a kid by my dad way back when was that it was used as a way to point the electrode towards a certain point in the combustion chamber.
He swore up and down that it was the thing to do back in his stock car racing days, ive never tried it on a bike.
- LarryC
05 Mar 2014 02:33
I've never seen any measured results from indexing spark plugs. It can however help create a more efficient burn of the charge in the chamber. These old hemi head motors will tolerate a great deal of inaccuracies and still run down the road pretty well. You're certainly not going to hurt anything by helping the combustion process be more efficient.....
Larry C.
- zed1015
05 Mar 2014 02:51
On engines with the plug mounted to one side of the combustion chamber the earth electrode can shield the spark from the fuel charges core.
Indexing the plug so that the spark is open and facing the center of the combustion chamber gives the best chance for a full burn.
Whether or not there is any actual measurable improvement in power and efficiency is debatable but in racing any small chance of a gain over the competition is never dismissed.
Twin plugging, especially on large bore engines and those with high domed piston crowns is proven to give a fuller burn, a noticeable increase in power and reduce charge loss so there's no reason not to index your plugs if you think there might be a gain.
- bountyhunter
05 Mar 2014 12:33
But here's the problem.... this guy shows how to "side gap" a plug and get all that increased power.
www.instructables.com/id/Save-Gas-And-In...r-By-Side-Gapping-S/
Problem is, I know exactly what's going to happen. As the high voltage builds up on the coil secondary, an E-field increases between the electrodes until (at some point) it is strong enough to cause a spark to jump across which will likely be the shortest path nearest the electrode tip. As the plug ages, it will gradually burn the closer areas and the spark jump area will move away from the edge which increases the linear distance the spark has to jump. The point is, you still get a spark at some point across the contacts same as a standard plug. I honestly don't see how this can possibly increase power. Would like to see some actual data.
