- Thank you received: 4
Pistons
- jsnabbs
- 1981 kawiKZ440
01 Mar 2014 00:06 #623696
by jsnabbs
TIME TO TRADE IN THE PEDALS FOR SOME POWER
Pistons was created by jsnabbs
Could someone recommend some after market pistons for a KZ440A motor.
Im looking to recondition the motor and want to put some oversize aftermarket pistons in, what would you recommend and what is the biggest safe oversize to go to?
many thanks
many thanks
- Nebr_Rex
- Thank you received: 300
01 Mar 2014 03:59 #623710
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Pistons
I've heard of using GS 850/425 pistons but that requires machining the small end of
the rod . My solution in the link below involves an over bore and a milled head.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
The following user(s) said Thank You: PhenielG
- jsnabbs
- 1981 kawiKZ440
01 Mar 2014 06:51 #623727
by jsnabbs
Replied by jsnabbs on topic Pistons
if possible i want to get away without milling the head, what about something the likes of wiesco?
- Nebr_Rex
01 Mar 2014 08:00 #623744
by Nebr_Rex
Reread my post on Do the ton.com.
I used Wiseco pistons. All the info you need is there.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
jsnabbs wrote: if possible i want to get away without milling the head, what about something the likes of wiesco?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
The following user(s) said Thank You: jsnabbs
- jsnabbs
- 1981 kawiKZ440
01 Mar 2014 10:25 #623757
by jsnabbs
So much good info there, thanks
- Nebr_Rex
01 Mar 2014 16:36 #623776
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Your welcome.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
