- Thank you received: 1
KZ1000 shaft to chain question
- thanson
25 Feb 2014 21:16 - 25 Feb 2014 21:17 #623356
by thanson
KZ1000 shaft to chain question was created by thanson
hello, I have been having a hard time getting a straight answer to this question so I figure here is a good place to try. What internal engine/trans parts are changed from the kz1000 shaft drive to the kz1000 chain drive, in other words, can a person just swap all the parts from kz1000 shaft drive cases and swap those parts into chain drive cases? I am fairly confident the cases are slightly different where the shaft unit bolts to the cases from the chain version. Is there any difference in the trans output shaft or anything else for that matter? thanks
edit: when I refer the shaft drive model I am referring to the early "J" model shaft drive from the very early 80's
Last edit: 25 Feb 2014 21:17 by thanson.
The following user(s) said Thank You: fat rider
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
- Thank you received: 11
25 Feb 2014 21:35 - 25 Feb 2014 21:36 #623358
by gearheadmm
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
Replied by gearheadmm on topic KZ1000 shaft to chain question
Yes you should be able to do that.
I did it on a MKII. Actually used a GPZ conversion.
69.46.28.106/forum/11-projects/413221-80...st-recycled?start=40
See the end of this page. And search for the other thread.
Your cases should have two holes for the shift shaft.
If it doesn't make sure it is in the same location as it is on a chain case.
Swap the guts (output shaft), forks, shaft, drum, internal shifter lever, and cover.
Last edit: 25 Feb 2014 21:36 by gearheadmm.
