1982 Kawasaki GPz750 engine swap?
- farnie
19 Feb 2014 19:23
Does anyone know if a 1982 Kawasaki GPz750 engine (kz750 R) will fit into a 1984 Kawi Gpz750 frame?
Thanks,
Sean
Thanks,
Sean
Farnie
huntingroadgators.blogspot.com/
2007 Yamaha VStar 1100 Silverado Custom (current)
1978 Kawasaki KZ650 B/C?D hybrid (current cafe' racer project)
1978 Kawasaki KZ650 C (current bobber project
1978 Kawasaki KZ650 D (parts bike)
1985 Kawasaki GPZ 750 (past)
1978 Yamaha XS 360 (past and 1st MC)
- zukdave
Re: 1982 Kawasaki GPz750 engine swap?
20 Feb 2014 09:36
Check how wide the mount's on the case are.
Early motor's had wider mount's when I put the 83 GPz motor
in my 80 KZ650 I just had to make spacer's to fit all the bolt hole's are
in the same place.
in the same place.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- steell
21 Feb 2014 02:35 - 21 Feb 2014 02:36
I've seen a KZ750E motor in a 84 GPz750 frame.
Good part is you no longer will need the offset sprocket.
Go all out and put a GPZ1100 motor in it, there are/were a couple of those on here.
Last edit: 21 Feb 2014 02:36 by steell.
