not running on 2 or 3 - what do i do?? (2000 kz100
- z1000sandiego
18 Feb 2014 13:00
Hey guys,
Just picked up this z1000 that's been in a garage for 3 years, and I'm at my wits end. Really hoping someone knows what I'm going through here.
Its only firing on 1 and 4 - NOT on 2 and 3.
I've pulled the carbs and cleaned them, so unless i missed something, its getting fuel ok. I can pull the sp plugs on 2/3 and see fuel residue, so I suspect its electrical.
What colors should the coil 1 and coil 2 wires be? The left side has red and green; the right side has red and black. the diagram shows the opposite; coil 1 with a black wire and coil 2 with a green wire. Does this mean my coils are wired wrong? If so, why would the bike start right up and run on 2 cyls (1 and 4)? I've never owned anything with a quad carb setup, and I've never seen another z1k, so I don't know if my wires are crossed.
- moneypit
Re: not running on 2 or 3 - what do i do?? (2000 kz100
18 Feb 2014 18:25
Most of these bikes run two coils. 1 set runs to 1/4 cylinders and the other to 2/3. Take the plug wires and switch #1 to#2 and #2 to #1 #3 to #4 and #4 to #3 and if #2 and #3 fire and 1 and 4 dont, its a bad coil. someone may correct me if Im wrong for that year of bike or with a wiring diagram.
2-76 kz900
St Paul MN
St Paul MN
- F1schumie
22 Feb 2014 15:27
I can't remember the coil order but I do know I yanked the plugs on my 2000 z1000 with same issue turned the motor over a few times with plugs out..
I put new plugs in a ran perfect instantly.
Now is the best time before taking old plugs to clean around old plugs for dirt and debris and blow it out of there..
Also I go with stock plugs sometimes I've had issue with specialty plugs and the amount of amps/voltage to have them run consistent ..
- wireman
22 Feb 2014 18:13
try switching the power input wires from 1-4 with 2-3then do the same with plug wires ,then see if you have fire on 2-3.
that should help decide if its a coil or ignition problem.
- LarryC
23 Feb 2014 04:24 - 23 Feb 2014 04:26z1000sandiego wrote: Hey guys,
When the coil primary leads are reversed, it will backfire through the carburetors when you try to start it, IF both coils are functioning.
Larry C.
Last edit: 23 Feb 2014 04:26 by LarryC.
- candyskateboards
27 Feb 2014 20:50
I had the same problem. I put in new plugs and the bike fired up on all 4.
- F1schumie
27 Feb 2014 22:15candyskateboards wrote: I had the same problem. I put in new plugs and the bike fired up on all 4.
Agreed the cheapest fix.. I can't remember but no way 1 coil runs 1 and 4 I never remember such a stretch.. More like 1/3 and 2/4.. Plugs are so cheap and easy why not try .. Most original coils have the cylinder numbers on leads as well as yellow paint on carb settings..
- roy-b-boy-b
28 Feb 2014 12:32F1schumie wrote:candyskateboards wrote: I had the same problem. I put in new plugs and the bike fired up on all 4.
1/4 2/3
- koolaid_kid
28 Feb 2014 12:33
Actually, 1 coil fires cylinders 1 & 4, the other coil fires cylinders 2 & 3. Very standard configuration for inline 4s.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
