oil cooler or not on turbo bike?
- mrdatsunturbo
- mrturbo Norway
17 Feb 2014 23:57
I have searched forum but cant decide what to do.
Last summer i was running Lockhart oil cooler but was not happy with oil pressure.
Should i remove it or is there other things to do? restrictor or some rerouting lines?
I am shure oil cooler is good for the engine but not if turbo is loosing oil pressure.
- T_Dub
Re: oil cooler or not on turbo bike?
18 Feb 2014 03:13
I would remove it. There are a lot of guys in the UK running 750 turbos (bored out) without oil coolers.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
18 Feb 2014 04:52
Big question is how hot is the motor getting ? To Hot ?? Do you ride in heavy traffic with no air flow over motor ?
Is it real hot in Norway ? I have been planning to run a oil cooler on my turbo but have had good luck over all without one with the exception of getting stuck in traffic . Do you boost the motor constantly creating excess heat ?
- mrdatsunturbo
- mrturbo Norway
18 Feb 2014 05:22
No it is not hot in Norway and it is not often i hit maximum boost pressure,
so when engine is warm and i can read oil gauge on engine and it is less.
And also engine noise is more ticking on cruising.
So thanks a lot and i will remove oil cooler before summer.
Previous owner of turbokit had a turbo failure and i will not risk that.
18 Feb 2014 08:13mrdatsunturbo wrote: No it is not hot in Norway and it is not often i hit maximum boost pressure,
Was Just kidding about Hot in Norway :whistle:
Just change the oil regularly, Use Good ,proper oil, and you should be good to go.
When I was living and working in Phoenix Arizona I put a oil cooler on my Harley touring bike and was happy how it helped control engine temps, but in Northern climates if you don't ride in city traffic you will be fine.
Im not concerned with oil pressure readings as these motors require flow vs pressure and if oilcoolers were bad on these KZs I think OMR would pull his off his Phoenix based bike.
Enjoy the Turbo !!!!
- turboking
18 Feb 2014 09:56
no need to run oil coolers on any z based turbo....... :dry:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
