Idle Problem
- grumpy56
Idle Problem
16 Feb 2014 16:22
Have a 1982 KZ1000J, stock pipes, carbs, and air box. The bike would not idle when cold/warm so I raised the idle to 1000 RPM. However, when hot, it goes up to 1400 RPM (or so). All of this is with the enrichener/choke "off". Any suggestions? Thanks.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- grumpy56
Re: Idle Problem
16 Feb 2014 16:59
Update.....Fired it up just now and will not idle (cold/warm) without the choke on....It's like I never raised the idle speed previously.....
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- daveo
Re: Idle Problem
16 Feb 2014 17:20grumpy56 wrote: Update.....Fired it up just now and will not idle (cold/warm) without the choke on....It's like I never raised the idle speed previously.....
Fresh fuel? Recent carb work done? Daily rider?
1982 KZ1100-A2/1170 sleeper 😀
- grumpy56
Re: Idle Problem
16 Feb 2014 17:34
Fuel less than 2 weeks old. Nope, short rides on the weekends only. Rebuilt carbs 5 years ago and they have been great (until now). Adjusted valves about 300 miles ago (one tight one). 14K miles. Fires up immediately when cold, but can crank quite a while, especially when warm. Thanks.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- jonarmstrong
Re: Idle Problem
16 Feb 2014 17:35
Possibly drawing air at intake boots
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
- DFIGPZ
Re: Idle Problem
16 Feb 2014 17:46 - 16 Feb 2014 17:46
remove carbs clean all jets and passages remove intake boots and replace or reseal .
1984 750 Turbo
Last edit: 16 Feb 2014 17:46 by DFIGPZ.
- daveo
Re: Idle Problem
16 Feb 2014 17:57grumpy56 wrote: Fuel less than 2 weeks old. Nope, short rides on the weekends only. Rebuilt carbs 5 years ago and they have been great (until now). Adjusted valves about 300 miles ago (one tight one). 14K miles. Fires up immediately when cold, but can crank quite a while, especially when warm. Thanks.
Problem started after valve adjustment...could be carbs are out of synch. I'd be all-over those carbs, and verifying correct bowl-fuel levels using the clear tube method.
Good luck!
- grumpy56
Re: Idle Problem
17 Feb 2014 05:36
Appreciate the help. Will get into those boots and carbs.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
