- Thank you received: 33
KZ1000R chain conversion 630 to 530
- tommyboah
12 Feb 2014 09:54 #622013
by tommyboah
.Tommyboy
KZ1000R chain conversion 630 to 530 was created by tommyboah
i am thinking about doing a chain conversion on my KZ1000R going from the stock 630 to 530. I already have a brand new set of sprockets and 630 chain ready to go, but someone told me that i should change to 530. Is it worth the effort?
Thanks.
Thanks.
.Tommyboy
- koolaid_kid
- Thank you received: 99
12 Feb 2014 10:02 #622014
by koolaid_kid
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Replied by koolaid_kid on topic KZ1000R chain conversion 630 to 530
You have a small gain in less unsprung weight. The biggest advantage to making the conversion is the wide variety and prices of 530 chains vs. 630 chains.
If you already have the chain and sprocket set I would use them. Next time you need a set, do the conversion.
1983 GPz 750
- baldy110
- Thank you received: 512
12 Feb 2014 20:17 - 12 Feb 2014 20:18 #622067
by baldy110
Replied by baldy110 on topic KZ1000R chain conversion 630 to 530
I swapped to the 530 chain on my GPz1100 powered ELR clone. The is a more selections for chain and sprockets with the 530 chain and it is also cheaper.
Last edit: 12 Feb 2014 20:18 by baldy110.
