Did I put too much oil in the bike?
- JohnB
I searched the forum already and couldn't find a definitive answer. sorry if this is an easy question.
1983 KZ750 ltd f1 in San Francisco
- slayer61
- KZR FLAG RELAY CARRIER #62
- JohnB
Although it was due to sitting in the cold on the street . Here in SF, Garages are rare and expensive :pinch:
- JohnB
After slayer's suggestion, I warmed it up, shut the engine off, let it sit, and the oil came back to just below the fill line. Feeling great about a successful oil change I took a trip down to Pacifica, where the engine must have gotten hotter than before, because when I came to a stop and checked my oil again: Same problem, oil level too high in the window. So now I'm thinking I might have circulated the oil into my engine before, making it appear as if I didn't have too much, but maybe didn't warm it up enough for the oil to expand, and now with the oil nice and hot, the reading is too much oil. Going to take a little out now. Should I see the oil level in the window drop as I drain the oil from the plug, and can just stop when it looks right?
- Thank you received: 2829
- Topper
- Thank you received: 133
^^ That's smart.650ed wrote: If you do decide to remove some oil don't pull the drain plug. Just fish a small vinyl tube down the filler hole and siphon a little out. Ed
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
- Grumpy Ole Artist
- Eschew Obfuscation!
- Thank you received: 62
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
- NakedFun
- Thank you received: 99
How long it has been sitting.
What temperature the engine and oil are at.
How much oil you put in.
If you have verified 3.5 is correct with a filter, and you have accounted for whether or not you have an oil cooler installed, then if us most likely is the result of temperature.
Your bike is air/oil cooled. Unlike liquid cooling, the engine oil temperature fluctuates more than on a liquid cooled engine since the engine itself puts more heat unto the oil and doesn't have the thermal stability and capacity of liquid cooling.
If you rad riding aggressively, or in warmer weather, or idling more due to stop and go traffic, the oil will be hotter. Oil expands when heated, thus this expansion in volume will show as a higher level when warmer. So if the bike was hotter than your original running/level checking, it will be higher in the sight glass.
It sounds normal to me if you put in the correct amount and the engine got hotter due to idling in traffic and not having the cooling air over the engine....
Welcome to the world if air cooled bikes....
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
- JohnB
First, what is an oil cooler?
Second, I've acquired some vinyl fish tank tubing, and attempting to use it. I don't have a turkey baster, although that's a brilliant idea. I'm forced to suck it through the tube a little at a time. Is there a technique for getting the tube down to the oil? I have about a foot and a half, and when I feed that down and suck, it's not picking up any oil. I don't mind the mess that is the oil drain plug method, are there any downsides as far as accuracy with that method?
- NakedFun
You need to fish the tubing down into the sump of the bike. That PVC tube likes to curl so you will have to rotate it around until you find you can draw oil out.
Nothing other than mess and amount removed, you can do it through the drain plug just fine.
I think you are trying to expect brain surgery results from a sanitation engineer attempts. The oil level just needs to be between the marks on the glass when filled and standing up right and level. Your bike will most likely use oil, and you simply replenish. Check your manual or do a google search and verify capacity. You certainly have not added enough to cause a problem, because if it was ariating the oil, your oil pressure light would flicker....
Just ride the thing and start learning about your bike. Is this your first motorcycle? There are plenty of other items that should be addressed that you can learn about.....
An oil cooler is a finned device much like a radiator on a car. It will sit up, in front of the engine just below the lower triple tree. It will have a supply and return oil line plumbed into it. It simply circulates the oil through it to shed heat. Oil coolers require additional oil be added to the factory capacity simply because you are adding system volume.
Cory
1976 Kawasaki KZ900
- JohnB
The oil is completely filled in the glass, nowhere in between the two marks. I know it's probably not too big of a deal, I'm just overly cautious because...NakedFun wrote: The oil level just needs to be between the marks on the glass when filled and standing up right and level.
Yep, first bike, got it a month ago. I've wanted one since I was 16. 26 now and I'm in love with it. The only thing I've done is replace the spark plug caps when cylinder #1 started misfiring (seemed to fix it), and had someone balance the carbs because I don't have(nor know how to use yet) a vacuum gauge. Is there a thread for things I should specifically look for in a bike that's new to me, or would you mind listing a few things to get me started? At some point I want to simplify the wiring harness with the resources on this forum. What else?Is this your first motorcycle? There are plenty of other items that should be addressed that you can learn about.....
- Z1Driver
- love the smell of triple smoke
- Thank you received: 55
Having to use the street would prove to be a pain.
Blue 1975 Z1B
Red 2009 Concours 14
