'83 KZ750 Twin Flywheel Removal Tool?
- splazoid
10 Feb 2014 18:46
No, the rear axle, frame head pin, or swing arm shaft will not work, they're all the incorrect thread diameter, I've checked.
What tool do I need to remove this flywheel?
- 4TheKZ1000
Re: '83 KZ750 Twin Flywheel Removal Tool?
10 Feb 2014 19:24Please Log in or Create an account to join the conversation.
- steell
10 Feb 2014 20:26
Never had an 83 750 twin, but I have pulled the rotor on 76-82 750 twins using the rear axle.
The parts diagrams at kawasaki.com says your flywheel is identical to the 82 model, so 76-80 axle should work to remove it.
Just found the problem, 82 M1 and 83 K1 use a 16mm axle, all the other 750 twins use a 17mm axle.
17mm bolt, probably 1.50 - 1.75 mm pitch (check it) should work.
