Engine oil viscosity
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
08 Feb 2014 07:18
#621522
10W 40 or 20W 50 :huh:
Which to use :unsure:
1982 KZ1100-A2/1170 sleeper 😀
Re: Engine oil viscosity
08 Feb 2014 08:00
#621527
Either is acceptable, but unless you live in a very hot climate or run the bike very hard I would recommend 10W-40. At least, that's what I have always used. The lower viscosity allows it to circulate easier when the engine is cold. Ed
  • daveo
  • Premium Member
  • Premium Member
08 Feb 2014 09:13
#621532
650ed wrote: Either is acceptable, but unless you live in a very hot climate or run the bike very hard I would recommend 10W-40. At least, that's what I have always used. The lower viscosity allows it to circulate easier when the engine is cold. Ed
Will 20W 50 provide enhanced wear protection, for an extended time (between oil changes) compared to 10W 40?
08 Feb 2014 09:31 - 08 Feb 2014 09:32
#621533
No. The recommended oil change intervals are the same for either weight oil. Ed
Last edit: 08 Feb 2014 09:32 by 650ed.
  • Nessism
  • Nessism's Avatar
08 Feb 2014 09:55
#621535
Shell Rotella 15W-40. Good stuff. Cheap. Get the synthetic is you'd rather which is 5W-40.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
08 Feb 2014 10:41
#621543
Run Rotella 15W-40 non- sync. You can pu a 4 qt container for $11.99 or less on sale.
No need to run sync oil.
  • turboking
  • turboking's Avatar
08 Feb 2014 10:54
#621545
:pinch: I run rotella in all my bikes , turbo or N/A.....15-40 ;) ;) No synthetic for me :S
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • daveo
  • Premium Member
  • Premium Member
08 Feb 2014 12:23
#621548
turboking wrote: :pinch: I run rotella in all my bikes , turbo or N/A.....15-40 ;) ;) No synthetic for me :S
+1
I've been using Brad Penn V2 "Green Oil" for a couple riding seasons, and started out with a case of 10W40, and switched to 20W50 last year, and like the way the engine runs with that. It takes a little longer to thin-down (when warming up), but the engine runs quieter, especially on those (nearly forgotten) hot days. :)
  • turboking
08 Feb 2014 12:31
#621549
+1
brad penn is the old green "kendall" oil for those that aren't old enough to remember...........you can get it in straight weights.......IMO....good stuff for racing.....a local speed shops sells it close to me for about $5 a quart. :S
I get my rotella on sale usually at wallyworld......... :side:
1985 GS 1150E
1983 GS 1100E
The following user(s) said Thank You: PLUMMEN, daveo
  • daveo
  • Premium Member
  • Premium Member
08 Feb 2014 13:35
#621554
"all my bikes"...a mighty herd of wild beasts! :ohmy: :woohoo: :whistle:
  • bountyhunter
  • bountyhunter's Avatar
08 Feb 2014 14:07 - 08 Feb 2014 14:08
#621557
No. I use 10-40 in the winter and in the summer I use a 50-50 blend of 10-40 and 20-50. But 10-40 alone is adequate. The most important thing is to change the oil and not push it. factory spec is 3000 miles, I change it sooner.
Last edit: 08 Feb 2014 14:08 by bountyhunter.
  • koolaid_kid
  • koolaid_kid's Avatar
08 Feb 2014 15:47
#621566
Actually, there is something far more important: do NOT use an energy conserving oil. They will make your clutch slip.
Second to that is to use an oil with good shear qualities for the transmission. Motorcycle oils have these qualities. Diesel oil, such as the aforementioned Rotella, also have these qualities at a significantly lower cost.
Dealer's choice.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
