oil leak in ignition cover
- jonarmstrong
02 Feb 2014 16:36
I have quite a bit of oil in my ignition cover. When I put the motor together after the po had taken it half way apart, the crank end looked rough. I Emory clothed it but it wasn't perfect when I put the seal in. What's the fix for this? Is there a seal saver sleeve for the end of the crank?
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
- 4TheKZ1000
Re: oil leak in ignition cover
02 Feb 2014 16:46 - 02 Feb 2014 16:58
On my 1980 A4 MKII, the top screw to the round ignition box is taped into the case.
If thread sealer is not used, it can leak oil.
Don't know about a 82
Last edit: 02 Feb 2014 16:58 by 4TheKZ1000.
- jonarmstrong
02 Feb 2014 17:13
Thanks. I'll look at that
- jonarmstrong
06 Feb 2014 18:49
Looked in ignition cover and found the oil leak is def at the crank. The seal is new but the crank had some pitting. I Emory clothed it when I put it back together last year but it has continually leaked. I'm guessing the only fix is to pull the crank. Has anyone heard of a crank sleeve for this problem?
06 Feb 2014 19:01
You may want to contact these folks and get their opinion on filling the pits. Ed
www.marinecrankshaftinc.com/motorcycles.html
The following user(s) said Thank You: jonarmstrong
- jonarmstrong
06 Feb 2014 20:10
Ed to the rescue again! Thanks. You are awesome!
