KZ440-D4 Drive belt
- cegonzalez37
KZ440-D4 Drive belt
31 Jan 2014 10:36
Hey guys,
I have an '82 KZ440-D4 and I'm trying to find a replacement drive belt and I'm having some trouble. I went to Kawasaki's website and got a part number for the belt which is 59011-1009. The part is no longer active but I noticed it had a superseded part number of 59011-1003. I believe I found both parts online but the 1009 belt is around $300 where as the 1003 belt is only around $40. Am I safe going with the superseded part or do I need to spring for the new part number? And if so, is there anywhere I can find one for cheaper? I was trying to find specs on the 1003 belt to see if it had the same teeth and length but I could not locate any info.
Thanks for an help in advance!
1982 KZ440-D4 - Owned since April, 2013
- daveo
Re: KZ440-D4 Drive belt
31 Jan 2014 10:58Otherwise, this may be an option: www.mcmaster.com/#timing-belts/=qhr8jg
1982 KZ1100-A2/1170 sleeper 😀
The following user(s) said Thank You: cegonzalez37
- Cynjut
31 Jan 2014 11:46
There was a really good thread on here a couple months ago about the numbering system for drive belts and the 'universal' nature of toothed drive belts. It was buried in a thread about damaging belts with rocks while driving, IIRC.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
31 Jan 2014 12:03
As you stated, both belts should be the same as one superseded the other (see Kawasaki.com chart below). The list price for both 59011-1009 and 59011-1003, when they were available, was the same - $337. If I needed the belt and saw a new old stock one for $40 I would buy it (assuming it is not a used belt). The best I was able to find is a 59011-1009 belt for $202 at
www.themotorcyclepartsoutlet.com/cgi-bin/store/index.cgi
. Ed
Attachment 00007_2014-01-31.jpg not found
- cegonzalez37
31 Jan 2014 12:48
Thanks for the info and advise.
31 Jan 2014 14:40
Just throwing it out there... I'm pretty sure you can convert the 440 belt to chain drive.
