Where to find big bore gasket kits?
  • PetterA
  • PetterA's Avatar Topic Author
27 Jan 2014 04:52
#620199
I need to change top end gaskets on my Z1000R2 ELR -83 because of bad compression etc. A complete engine gasket set would also work!
I have a 75mm cylinder bore (1166cc?) and the previous head gasket was 76,5mm.
Where can I find a complete top end gasket set for my bore? No luck on eBay...
-83 Z1000 Eddie Lawson Replica
-71 H1 Mach III
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Where to find big bore gasket kits?
27 Jan 2014 05:03 - 27 Jan 2014 05:44
#620200
Was ELR based off of the J-model engine platform, If so.....a J-model gasket will work. I would assume it was a J engine.
OK, here you go, some stuff for 83 ELR. I would call them to inquire about the oversized gaskets.
www.z1enterprises.com/ShopByCategory.asp...egory=01010104093206
These guys have a 76mm gasket for a J-model engine.
www.dynoman.net/engine/gaskets-cometic.html#kawa
Last edit: 27 Jan 2014 05:44 by 4TheKZ1000.
  • Nebr_Rex
  • Nebr_Rex's Avatar
27 Jan 2014 05:03
#620201
Profile?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: 4TheKZ1000
  • turboking
  • turboking's Avatar
27 Jan 2014 06:02
#620211
:blink: as far as I know no one sells a complete oversize bore gasket kit. :huh: you purchase the head and base gasket for your bore separately ..... :unsure:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • PetterA
27 Jan 2014 09:56
#620235
Yeah looks like I have to buy them separately.
What type of head gasket should I go with?
1-piece or 2-piece?
Paper type or copper?
-71 H1 Mach III
  • StreetfighterKz
  • StreetfighterKz's Avatar
27 Jan 2014 09:58
#620236
I believe that copper only works well if you have your cylinders O-ringed other wise a one-piece paper would be the way to go.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • zed1015
  • zed1015's Avatar
27 Jan 2014 10:00
#620238
One piece COMETIC graphite head gasket.
Fill the cam tunnel 'O' ring groove with RTV and slice It flush with the barrel face once cured.
  • DFIGPZ
  • DFIGPZ's Avatar
27 Jan 2014 16:04
#620271
PetterA wrote: I need to change top end gaskets on my Z1000R2 ELR -83 because of bad compression etc. A complete engine gasket set would also work!
I happen to have a brand new base gasket that will work.
Barry
1984 750 Turbo
  • wireman
  • wireman's Avatar
27 Jan 2014 17:24
#620282
How about a top end gasket kit for a gpz1100?
  • PetterA
28 Jan 2014 08:18
#620340
Thanks, looks like Z1enterprise have what I need (together with other things I need), although it´s a 2-piece gasket, does it make any difference as long as i have the cam tunnel gasket as well?
-71 H1 Mach III
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
28 Jan 2014 15:02
#620378
i would recommend going with a one piece gasket if possible.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
