Frozen clutch cable
- Britome
Re: Frozen clutch cable
27 Jan 2014 12:01
While I'm asking... Is there a specific valve shim kit I should get? Once I get into it, I want to have parts available.
- JimB
27 Jan 2014 17:58
Steel,
You are correct,...I got confused. The rod goes in the hole just like mother nature intended.
Britome,
You may want to look for a replacement part that does not use ball bearings. later versions eliminated the ball bearings. Not sure what year they switched over?
Z1 has a nice shim kit,...make sure you get the tool for removing them.
Jim
Britome,
Jim
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
- Britome
27 Jan 2014 18:42
"Steel rod goes in the hole" the line of the thread!
I ordered the bearings but if there is such a replacement part, I would be all over it.
- Britome
27 Jan 2014 19:10
Houston we have a problem....
All this talk about steel rods prompted me to try to push it in with a hammer. It wouldn't budge. This tells me the problem wasn't a simple bearing issue on that mechanism but something much more sinister.
Help!!!
Help!!!
27 Jan 2014 19:26
WOAH THERE BIG GUY! I think it is really unlikely that you could disengage the clutch that way. Even stock springs are pretty stout. Sometimes the plates will stick after sitting up a while, but they can often be loosened up by rocking the bike back and forth with the clutch lever pulled in.
Try fixing or replacing the release mechanism in the first pic and be sure the cable is 100%.
The mechanism used through 1981was changed in 1982, so if you replace it, be sure to get the right one.
27 Jan 2014 20:13
I'm here to fix your clutch. I can tune those carbs while I'm at it for no extra charge. :laugh: :laugh: :laugh: :laugh:
Attachment 00005_2014-01-27.jpg not found
27 Jan 2014 20:46 - 27 Jan 2014 20:52
Last edit: 27 Jan 2014 20:52 by martin_csr.
- Z1Driver
- love the smell of triple smoke
27 Jan 2014 23:26 - 27 Jan 2014 23:37Houston we have a problem....
Don't do that......it's like trying to clean your dinky with a wire wheel. :ohmy:
Can you grab it and pull the rod out? To remove the screws you may have to get the proper JIS screw driver tip. JIS is actually different than a Phillips even though they look the same.
Blue 1975 Z1B
Red 2009 Concours 14
Last edit: 27 Jan 2014 23:37 by Z1Driver.
- Britome
28 Jan 2014 04:01
Thx, guys. Yes, I can pull my rod out... Heh heh
I won't do anything until the ball bearings come in. The clutch was permanently engaged before I pulled the assembly apart so I guess I'm over thinking.
- Britome
06 Feb 2014 13:51
All the parts came in from bike bandit. Glad I ordered a couple extra bearings. Feeding those suckers in the right place with the grease and getting the pivot arm positioned right took about 10 tries. In the end all is perfect and clutch works
I'm sure to have about a dozen similar problems. I hope I can lean into you all for my next issue.
Thank you very much!
