gpz cam swap
- OnkelB
Re: gpz cam swap
26 Jan 2014 06:41 - 26 Jan 2014 15:18
Look at the cams just right of the sprocket mount where the tach drive worm gear would be.
If one cam has one groove there and the other has none, they're 81 cams - if both cams have three grooves they're 82 cams.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 26 Jan 2014 15:18 by OnkelB.
The following user(s) said Thank You: jonarmstrong
- jonarmstrong
Re: gpz cam swap
26 Jan 2014 07:52
The cams are coming in this week. I will look as soon as I get them. Just for general knowledge... Which one is which on the 81 and does it matter on the 82? Thanks for the help
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
- OnkelB
Re: gpz cam swap
26 Jan 2014 08:07 - 26 Jan 2014 15:29
For the 81 cams, the one with the groove is the intake cam (12044-1031), the one with no groove is the exhaust cam (12044-1036).
The three-groove 82 cams (12044-1037) are identical, the position of the sprocket determines which is intake and which is exhaust.
Edit: Removed some incorrect info, sorry - see my next post below for added info about the cam sprockets.
Last edit: 26 Jan 2014 15:29 by OnkelB.
- jonarmstrong
Re: gpz cam swap
26 Jan 2014 08:25
Thought so on the 82's. Will my gears work on the 81's ?
- NakedFun
Re: gpz cam swap
26 Jan 2014 11:59
What KZ are you installing them into? Earlier KZ's used a roller chain vs the HY VE chains used on the later KZ's and GPZ IIRC. Due to the different cam gear bolt pattern, you cannot bolt your stock KZ sprockets on the GPZ cams if your KZ is a pre-81 model, thus the need for the adapter can gears from APE. Someone will correct me if I am off base. If you are putting cams in, are you running aftermarket exhaust and intake filter/pods?
Cory
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- steell
Re: gpz cam swap
26 Jan 2014 14:30Nebr_Rex wrote:jonarmstrong wrote: And my tach doesn't read off the cam. I have no wires to the top of head
Cams are either driven by cable off the exhaust cam (early KZs )
or off the ignition ( late KZs ).
Learned something new today, I was under the impression that the cams were driven by the crank via a chain.
:evil:
Just couldn't help myself :lol:
- OnkelB
Re: gpz cam swap
26 Jan 2014 15:26 - 26 Jan 2014 15:27
The 81 GPz 1100 cams use the same cam sprockets (12046-1025) as these models:
KZ1000-J1 (1981)
KZ1000-J2 (1982)
KZ1000-J3 (1983)
KZ1000-K1 (LTD) (1981)
KZ1000-K2 (LTD) (1982)
KZ1000-M1 (CSR) (1981)
KZ1000-M2 (CSR) (1982)
KZ1000-P1 (Police 1000) (1982)
KZ1000-P10 (Police 1000) (1991)
KZ1000-P11 (Police 1000) (1992)
KZ1000-P12 (Police 1000) (1993)
KZ1000-P13 (Police 1000) (1994)
KZ1000-P14 (Police 1000) (1995)
KZ1000-P15 (Police 1000) (1996)
KZ1000-P16 (Police 1000) (1997)
KZ1000-P17 (Police 1000) (1998)
KZ1000-P18 (Police 1000) (1999)
KZ1000-P19 (Police 1000) (2000)
KZ1000-P2 (Police 1000) (1983)
KZ1000-P20 (Police 1000) (2001)
KZ1000-P21 (Police 1000) (2002)
KZ1000-P22 (Police 1000) (2003)
KZ1000-P24 (Police 1000) (2005)
KZ1000-P3 (Police 1000) (1984)
KZ1000-P4 (Police 1000) (1985)
KZ1000-P5 (Police 1000) (1986)
KZ1000-P6 (Police 1000) (1987)
KZ1000-P7 (Police 1000) (1988)
KZ1000-P8 (Police 1000) (1989)
KZ1000-P9 (Police 1000) (1990)
KZ1000-R1 (Eddie Lawson Replica) (1982)
KZ1100-A1 (Shaft) (1981)
KZ1100-A2 (Shaft) (1982)
KZ1100-A3 (Shaft) (1983)
KZ1100-B1 (GPz) (1981)
KZ1100-D1 (Spectre) (1982)
KZ1100-D2 (Spectre) (1983)
KZ1100-L1 (LTD Shaft) (1983)
ZN1100-B1 (LTD Shaft) (1984)
ZN1100-B2 (LTD Shaft) (1985)
The 82 GPz 1100 cams use the same cam sprockets (12046-1033) as these models:
KZ1000-R2 (Eddie Lawson Replica) (1983)
KZ1100-B2 (GPz) (1982)
ZX1100-A1 (GPz) (1983)
ZX1100-A2 (GPz) (1984)
KZ1000-J1 (1981)
KZ1000-J2 (1982)
KZ1000-J3 (1983)
Last edit: 26 Jan 2014 15:27 by OnkelB.
- jonarmstrong
Re: gpz cam swap
27 Jan 2014 06:22 - 27 Jan 2014 06:23
You are the wind beneath my wings steell! Surely if there's room in your plethora of knowledge to learn something new, there's hope for an idiot like myself! Thanks for the help everyone
Last edit: 27 Jan 2014 06:23 by jonarmstrong. Reason: premature postilation
- jonarmstrong
Re: gpz cam swap
27 Jan 2014 06:43. It's written as my signature. It's an 82ltd w pods and a 4into1. I freshened the bore and did a valve job about 4000 miles agoNakedFun wrote: What KZ are you installing them into? Earlier KZ's used a roller chain vs the HY VE chains used on the later KZ's and GPZ IIRC. Due to the different cam gear bolt pattern, you cannot bolt your stock KZ sprockets on the GPZ cams if your KZ is a pre-81 model, thus the need for the adapter can gears from APE. Someone will correct me if I am off base. If you are putting cams in, are you running aftermarket exhaust and intake filter/pods?
Cory
- steell
Re: gpz cam swap
27 Jan 2014 15:55jonarmstrong wrote: You are the wind beneath my wings steell! Surely if there's room in your plethora of knowledge to learn something new, there's hope for an idiot like myself! Thanks for the help everyone
Hope you're not offended, it was just a humorous take on a simple mistake
- jonarmstrong
Re: gpz cam swap
27 Jan 2014 16:37
Oh I'm not. Just poking back a bit. I do appreciate the help you guys give, I have learned a lot from the forum. Nice bike in your avatar!
- NakedFun
Re: gpz cam swap
27 Jan 2014 16:49
Sorry, thought I would ask anyway since I have been bitten by the assuming the one in the sig is the one being wrenched on!
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
