Pulling rotor off Kawasaki KZ250
- Awaz
21 Jan 2014 17:41
I need to inspect the starter chain as it appears the starter does not engage the flywheel consistently and makes lot of spinning noise. I have the left side cover off, but do not have anything to pull the rotor off. What tools do I need to pull the rotor off so I can inspect the chain?
- Topper
Re: Pulling rotor off Kawasaki KZ250
21 Jan 2014 18:18
Not sure about the 250, but usually you need a flywheel puller which is basically a reverse threaded bolt that pushes the flywheel off.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- Awaz
