Kz1000 engine overhaul
  • capnkente1
  • capnkente1's Avatar Topic Author
20 Jan 2014 16:36
#619342
Greetings fellows..........
Any one know of a place where I can get my 1978 KZ1000a2 motor overhauled that won't cost an arm and a leg?
Just looking for a good, stock complete rebuild.
any ideas?
I have contacted Redline Cycle in Skokie, and Jim doesn't have any more cores, he sold them all.
  • JimB
  • JimB's Avatar
Re: Kz1000 engine overhaul
20 Jan 2014 17:35
#619349
What specifically are you looking to do? Usually the bottom end will last a long time (I have 50k on my motor),...is there a problem or do you just want to get it done. If you do not need the bottom end redoone then you can focus on the pistons and cylinders, vavles, etc. I would spend the money on the top end of the motor.
Jim
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
  • capnkente1
20 Jan 2014 19:03
#619367
Thanks, Jim..............
The motor has about 37K on it and the tranny is howling and vibrating on the low end, also an oil leak that I cannot find on the lower right side somewhere, plus smoking(rings probably). I want to keep this thing around for awhile, and would like to start afresh.
Kent
  • DFIGPZ
  • DFIGPZ's Avatar
20 Jan 2014 19:23
#619372
where are you located ?
1984 750 Turbo
  • capnkente1
20 Jan 2014 19:27
#619375
Houston, Tx area.........
