KZ550 Camshaft position opposite manual & Lou D
  • TomasDouglas
  • TomasDouglas's Avatar Topic Author
20 Jan 2014 14:40
#619318
I set the 1 - 4 piston to the T mark however the camshafts are completely opposite the manual and Lou D's pictures on his website. I was dumb founded how can this be. Can the engine still turn over with the camshafts opposite?
I am rebuilding a 1980 KZ550 and the PO said it hadn't run in 12 years and he thought the problem was the coil or ignition. I used a car battery to check the compression and got 90, 120, 120, 130. I then took the valve cover off to check the valve clearances. That's when I found the opposite camshaft positions. I am confused is there something I am missing or not comprehending or doing wrong?
Thanks Tomas
1-4 piston at T
Attachment IMG_0272.jpg not found
Exhaust cam EX upside down on inside Intake cam Z5 upside down on inside
Attachment IMG_0274.jpg not found
#1 cylinder on left both cam lobes pointing in
Attachment IMG_0275.jpg not found
Tomas Douglas
1980 KZ 550A
1986 GPZ 550
  • OnkelB
  • OnkelB's Avatar
Re: KZ550 Camshaft position opposite manual & Lou D
20 Jan 2014 16:04
#619335
One camshaft revolution takes two crank revolutions, you're stuck in the middle so to speak - turn the crank one full turn till you hit the 1/4 mark again and the cams should align correctly.
77 KZ 650 B1, 82 GPz 1100 B2.
The following user(s) said Thank You: TomasDouglas
  • turboking
  • turboking's Avatar
20 Jan 2014 16:07
#619336
nothing wrong. :ohmy: they are in time. ......1 revolution of crank will put them right per the manual....but DO NOT turn engine over without the cover or cam caps installed.........probably bent valves will result also has automatic cam chain adjuster......
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • Dr. Gamma
  • Dr. Gamma's Avatar
20 Jan 2014 16:07
#619337
OnkelB wrote: One camshaft revolution takes two crank revolutions, you're stuck in the middle so to speak - turn the crank one full turn till you hit the 1/4 mark again and the cams should align correctly.
Thats it in a nut shell. Just put your cam caps back on before you rotate motor!!!!
1986 RG500G 2 stroke terror.
  • OnkelB
  • OnkelB's Avatar
20 Jan 2014 16:14
#619338
Oops, missed the bit about the caps, good catch - watching and posting from my phone, pics are kinda small...
  • TomasDouglas
20 Jan 2014 21:31
#619381
Thanks for the response
Could I just remove the camshafts, keep the chain tight and rotate the crank 1 full turn instead of reinstalling everything?
Thanks Tomas
Tomas Douglas
1980 KZ 550A
1986 GPZ 550
  • OnkelB
  • OnkelB's Avatar
21 Jan 2014 00:54
#619390
One four-stroke cycle = 1 camshaft rotation = 2 crank rotations, so in each cycle the crank will hit the timing mark twice - you're currently positioned in the middle of the cycle (2 strokes in) rather than at the beginning.
In other words you don't need to reinstall anything, just rotate the crank one full turn (= 1/2 cam rotation) to finish the cycle and you're set.
