Adding oil cooler to 750E2
  • Nessism
  • Nessism's Avatar Topic Author
19 Jan 2014 07:08 - 19 Jan 2014 07:18
#619148
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationRead through a bunch of threads in the archives about adding an oil cooler to a 650 or early 750. Info suggests a GPZ 750 oil pan and cooler are a direct bolt on (other than the frame mount for the cooler). But what about the later ZR750 oil cooler and lines (or even oil pan)? The later parts are plentiful on ebay and seem less weathered and worn than the early parts. Would like to find the best possible solution.
Thanks in advance.
Edit:
Nice clean later model oil pan...
And cooler...
Last edit: 19 Jan 2014 07:18 by Nessism.
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Adding oil cooler to 750E2
19 Jan 2014 08:04
#619153
Looks similar, go for it.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Nessism
19 Jan 2014 08:39
#619157
Oil pan gasket part number is same for ZR-7S and the earlier engines.
