Oil cooler
  • Zapzuta
  • Zapzuta's Avatar Topic Author
Oil cooler
18 Jan 2014 18:01
#619114
Need some ideas for an oil cooler. Any ideas and were to
Get one. Thanks
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Oil cooler
18 Jan 2014 18:14 - 19 Jan 2014 07:23
#619115
This is a good size. I have used this one and is a very nice fit.
I used a Earls 13 row cooler, link provided. I did get mine in black.
While build process, I wanted room up-front for a bigger oil cooler than a Lockhart. I did remove the bulky looking front frame brace and beefed up the neck and down tubes bracing during the rake process. You will have to work around this brace on your bike.
www.summitracing.com/parts/ear-21306erl/overview/
www.jegs.com/p/Earls/Earls-Temp-A-Cure-N...ers/1675460/10002/-1
Attachment bike0631024x683.jpg not found
Attachment bike0121024x683.jpg not found
Attachment bike0651024x683.jpg not found
Attachment bike0351024x666.jpg not found
Attachment bike0381024x679.jpg not found
Attachment bike0111024x624.jpg not found
Last edit: 19 Jan 2014 07:23 by 4TheKZ1000.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: Oil cooler
18 Jan 2014 18:29
#619117
i would reccomend the earls 13 row cooler.
You can buy fittings for the bypass from z1 enterprises or ebay
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • Dr. Gamma
  • Dr. Gamma's Avatar
Re: Oil cooler
18 Jan 2014 18:59
#619122
Nice idea for the bracket and clamps that fit around frame tubes to mount the oil cooler!!!
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: 4TheKZ1000
  • Zapzuta
Re: Oil cooler
18 Jan 2014 20:31
#619126
Awsome thanks
  • dejavoodo41
  • dejavoodo41's Avatar
Re: Oil cooler
20 Jan 2014 06:42 - 20 Jan 2014 06:50
#619262
I'm using this one pitstopusa.com/i-5078411-tru-cool-heavy-...er-75000-btu-hr.html and got the oil blocks from either americanclassix or Z1E I can't recall which.
I was on a pretty tight budget when I did it so it's not the best looking but it works. Since the post after my install I have added a small fan that I found on a site that deals with scooters and go- cart so when I'm in slow traffic I can turn it on to have some extra air flow.
www.kzrider.com/forum/2-engine/537526-fi...oil-cooler-installed
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Last edit: 20 Jan 2014 06:50 by dejavoodo41.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
Re: Oil cooler
20 Jan 2014 15:11 - 20 Jan 2014 15:14
#619323
4TheKZ1000 wrote: I used a Earls 13 row cooler...
Zapzuta, note that 4TheKZ1000 does not have a tachometer cable on that bike. It looks like your bike still has the mechanical tach.
if you want to keep the tach cable (and the stock frame bracing) that 13 row cooler is going to be pretty tall. When I looked into this before even the 10 row seemed a bit tall.
Earl's also makes curved coolers: www.holley.com/types/Temp-A-Cure%20Curved%20Oil%20Coolers.asp
My dad's '74 Z1
'00 ZRX1100
Last edit: 20 Jan 2014 15:14 by DOHC.
  • Bozo
  • Bozo's Avatar
  • Ride it like u stole it
Re: Oil cooler
20 Jan 2014 15:25 - 20 Jan 2014 15:56
#619326
dejavoodo41 wrote: I'm using this one pitstopusa.com/i-5078411-tru-cool-heavy-...er-75000-btu-hr.html and got the oil blocks from either americanclassix or Z1E I can't recall which.
That earl's cooler looks really nice, On my Yamaha FJ1200 I have fitted the Pitstop style cooler which appears to do the job well ( I have a KLX250 cooler fan behind it)- the yamaha runs EXTREMELY hot (Perth Oz 38degree C temperatures aren't a problem).
My Z1R runs an El cheapo GPZ1100 B2 cooler.
[IMG
Its the only picture showing the cooler I have in hand, it does a good job. I did forget to prime it (I had the engine out for a bearing replacement) the other day and after a slight drag the oil light came on and didn't go off after a short time (it was very hot) so take care when fitting one
[IMG
Last edit: 20 Jan 2014 15:56 by Bozo. Reason: adding more detail
  • ZERO
  • ZERO's Avatar
Re: Oil cooler
21 Jan 2014 02:23
#619396
I have a set of oil cooler inlet and outlets.(for the engine) for a Z1, Kz900/1000. I'd have to locate them in my garage, but I'd sell em cheap.
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
