Jumping Timing Chain
  • freakinbike
  • freakinbike's Avatar Topic Author
17 Jan 2014 10:02
#618963
I recently did a head rebuild, and upon reconstruction, my cam chain jumps. It will jump once per full revolution. I'm wondering if there's something going on with the timing, or if my automatic tensioner has gone out.
This is a 1982 GPz750, new valves, cut seats, new shims, gaskets, etc (full rebuild).
1982 GPZ750, stock (for now..)
1973 VW Bus
Can life really get much better?
  • turboking
  • turboking's Avatar
Re: Jumping Timing Chain
17 Jan 2014 11:21
#618966
sounds like the cam chain is not running on the crank sprocket......likely off to one side of it...IMO :(
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
  • Away
17 Jan 2014 11:29 - 17 Jan 2014 11:30
#618967
Id have to agree with turbo king. but could be the tensior.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Last edit: 17 Jan 2014 11:30 by Powerstroke_fan.
  • Cynjut
  • Cynjut's Avatar
17 Jan 2014 12:14
#618976
Obvious stupid question - did you release the tensioner after you put it back in?
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • baldy110
  • baldy110's Avatar
17 Jan 2014 12:22
#618978
Do you have the top cover installed when you turn the engine over? There is a tensioner on the bottem of the valve cover that pushes down on the camchain when installed.
  • freakinbike
17 Jan 2014 16:53
#619015
How does one go about "releasing the tensioner"? And yes, I have tried it with the valve cover installed, same issue.
1973 VW Bus
  • steell
  • steell's Avatar
17 Jan 2014 17:01
#619017
How do you know your cam chain is jumping after one revolution of the crank? The crank turns twice for every one cam revolution.
17 Jan 2014 17:09
#619020
If your cam chain is jumping doesn't that mean the valve timing relative to the crank is shifting? That being the case, do you know if you have had contact between the valves and pistons? Ed
  • freakinbike
17 Jan 2014 18:44
#619038
When completing the rotation (turning the crank by hand), the chain will be taut, then something *pops* and the chain goes very slack.
I do not know if I have had contact between the valves and pistons. As far as I know, the timing has been spot on since forever. But then again, I've only put about 1000mi of the 36000mi on the bike.
1973 VW Bus
  • steell
  • steell's Avatar
18 Jan 2014 15:10 - 18 Jan 2014 15:12
#619089
Of course it does, that's the cam going over center and the valve springs rotating the cam.
Perfectly normal
To put it simply, you're seeing problems where there are none. No experience and a little nervous maybe?
Last edit: 18 Jan 2014 15:12 by steell.
18 Jan 2014 16:01
#619098
By jumping I thought you meant jumping a tooth on the sprockets. In other words, what I have always heard referred to as "jumping timing." That's why I asked about valve/piston contact - it seems impossibly to me for a KZ engine to jump a tooth on the cams every revolution of the crank without causing a nearly immediate valve disaster.
After reading Steell's posting I re-read this thread. I now think you are not saying the cam chain is actually slipping over a tooth on the cams, but merely getting tighter and looser as the engine rotates. As Steell points out, this is normal. That is why when adjusting the manual tensioner provided on some KZ's (like my KZ650-C1) the crankshaft needs to be oriented in a specific position in order for the slack to be taken up by the tensioner before the pinch bolt it tightened. Ed
  • freakinbike
18 Jan 2014 16:27
#619101
Ok, well that's good to hear. I have an automatic tensioner, I thought it was supposed to take up the slack so that the chain doesn't fall off.
1973 VW Bus
