- Thank you received: 2
Fouling plugs at idle....could it be valve seals?
- anotherZ
I tried the original #15 pilots, but the bike idles like crap and still fouls the plugs. Now I read somewhere it could be the valve seals?
Can you "read" from the plug whether it's black because it's running rich or the valve seals are shot?
As always, thanks for any help, this forum is a lifesaver
79 KZ 1000 LTD
Saved it from becoming a drag bike
Smaller tank
- koolaid_kid
- Thank you received: 99
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- anotherZ
79 KZ 1000 LTD
Smaller tank
- turboking
- Thank you received: 106
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
- turboking
1985 GS 1150E
1983 GS 1100E
- gpz1170
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- anotherZ
Bike smokes a bit, but not too bad, I don't think it's blue, looks more black or grey to me.
I have checked float levels with the clear tube method, so should be good.
79 KZ 1000 LTD
Smaller tank
- CustomBlueKZ900
- turboking
anotherZ wrote: Turboking, how can I tell when the choke circuit plungers are bad? I had the carbs apart, but didn't see anything out of the ordinary.
black smoke means it's fat (rich) :ohmy: ....make sure that your choke lever is working as it should, the screw/spring assy is not loose or moving. :blink: you can push down on the choke plungers to see if it helps...they are probably original ......did you disassemble the choke plungers off the rack and look at them? usually they are rock hard or have cracks and won't seal against the carburetor enrichener seats......they will pull fuel past the plunger at idle, creating a rich condition......just a thought as I have seen that be the problem before :S HTH
1985 GS 1150E
1983 GS 1100E
- turboking
1985 GS 1150E
1983 GS 1100E
- NakedFun
You would have to look down the intake and exhaust ports to visibly see if there are signs of oil coking on the back side of the valve and valve stem. If they are leaking that badly, then you should see signs of blue smoke coming from the exhaust,
I would say that even with pods and exhaust, you shouldn't have to vary from the stock pilots. If you put the stock pilots back in and it is is acting lean like its popping and surging, then there could be another issue going on such as:
Intake boot leaks
A/F screw leaking air/worn seats
Pilot circuit partially plugged
When you are looking at the plugs, are you looking at the same one, or all of them? Have you adjusted the need position? Did these carbs work for you before and this is a sudden change or is this a new bike to you? Have you been into the carbs deeper than just the jets since you have owned it?
Last think is your charging system and ignition system up to par? If you measure the voltage at the coils during idle, it should be at 13.5vdc or so. If this reading differs from your reading at the battery itself, then you may have a ign. coil connection problem due to resistance. Poor spark energy can lead to fouled plugs and your charging system's performance is worst at idle so any sketchy connections will present themselves there first.
Sincerely do not think it is leaking valve seals.......
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
- anotherZ
Customblue, main jets are 122.5 now. I had 117.5 in there and after 20 miles of (almost) WOT headers were totally blued out and plugs looked very lean. Now with 122.5, they seem spot on at WOT
Turboking, I had disassembled the choke plungers completely and didn't see anything out of the ordinary, however at that time I didn't know about the rich condition, so haven't looked THAT closely. Will definitely do if I take the carbs off next time. I don't think my float level is off. I have used the clear tube method very diligently, so I think I am good.
Cory,
Intake boots are brand new
I don't think the pilot circuit is plugged, had the carbs completely disassembled.
A/F screws, gaskets, seals are all new from the carb rebuild kit
When I look at the plugs I look at least at 2 at a time and always take two different ones, they all look very similar.
Needle is one click richer, mid range is great though, very responsive and correct plug color.
The carbs are off ebay. I bought the bike with 40mm Lectrons and got the current rack of VMs on ebay. The bike has never run better than now, it actually took me a long time to get to where I am, lots of main jet and needle changes.
I had totally disassembled the carbs and went through them.
Someone had told me about the voltage at the coils before, but haven't checked yet.
I think here is what I am going to do in this order:
Measure voltage at coils
Take off carbs, check choke plungers again
Look down intake (and maybe exhaust) ports to check for oil coking
Maybe go back to stock pilots
Thanks again for all that input! And let me know what you think of my approach
79 KZ 1000 LTD
Smaller tank
