Exhaust Stud Length?
- Greeno
14 Jan 2014 16:57 #618607
by Greeno
Exhaust Stud Length? was created by Greeno
Hi, I'm another new guy with a problem.
I've a barn find '77 KZ900.
it's dismantled and i don't have the the exhaust header clamps or studs.
I've seen M6 x 30mm and M6 x 46mm studs on sale for this motorcycle.
Anyone any idea which is right?
Thanks
Thanks
- 4TheKZ1000
- Visitor
14 Jan 2014 17:00 - 14 Jan 2014 17:37 #618609
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Exhaust Stud Length?
Last edit: 14 Jan 2014 17:37 by 4TheKZ1000.
- Greeno
14 Jan 2014 17:07 #618610
by Greeno
Replied by Greeno on topic Exhaust Stud Length?
No eBay APP ID and/or Cert ID defined in Kunena configurationI know it's ebay but not this?
- 4TheKZ1000
- Visitor
14 Jan 2014 17:46 - 14 Jan 2014 17:48 #618614
by 4TheKZ1000
Last edit: 14 Jan 2014 17:48 by 4TheKZ1000.
- Thank you received: 2098
14 Jan 2014 19:39 - 14 Jan 2014 19:47 #618640
by Patton
Other Kawasaki models use 8x30 studs.
But I don't know what uses 6x30.
Could thread a 6mm bolt into the head holes in order to confirm that the 6mm size has not been enlarged to 8mm as used on later models.
Lots of good info on kawasaki.com, including parts diagrams, part names, part numbers, fastener sizes, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
www.kzrider.com/forum/13-bike-related/37...imitstart=0&start=20
Replied by Patton on topic Exhaust Stud Length?
6x46 is the stock KZ900 exhaust stud.Greeno wrote: Hi, I'm another new guy with a problem.
Thanks
Last edit: 14 Jan 2014 19:47 by Patton.
The following user(s) said Thank You: Greeno
- Thank you received: 2829
14 Jan 2014 20:10 #618648
by 650ed
Replied by 650ed on topic Exhaust Stud Length?
According to Kawasaki.com they're 6 x 46 (see diagram below). They are still listed as an "Active" part, so any dealer can get them. Partzilla lists them at $3.27 each (see link). Ed
find.partzilla.com/?r=t&q=92004-049&x=6&y=9
Attachment 00003_2014-01-14.jpg not found
