APE K410 cams for '83 KZ1000R2 engine
  • tommyboah
  • tommyboah's Avatar Topic Author
14 Jan 2014 06:16
#618531
I am boring the engine og my '83 KZ1000R2 to 72mm and using a Wiseco piston kit with 10.25:1 compression. I am playing with the though of replacing the stock cams with APE K410 and also adding APE valve springs. I've read from another thread that the Wiseco 72mm and K410 are a good combo, but what do I need to do with regards to cam chain and cam sprockets? Can I use the stock setup?
Is there something other that I need to think through on this?
Thanks.
.Tommyboy
  • turboking
  • turboking's Avatar
Re: APE K410 cams for '83 KZ1000R2 engine
14 Jan 2014 06:34
#618532
your stock hyvo chain is plenty strong enough .....all you need to do is get a set of 3 bolt cam to hyvo cam sprockets from ape... :blink:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • crock62
  • crock62's Avatar
14 Jan 2014 06:53
#618535
Adjustable cam sprockets , hd cam chain and also clearancing the head and cover
  • turboking
14 Jan 2014 07:31
#618539
I'm not sure you will have to clearance , maybe a bit ,if any on the head or cover for the lobes with a .410 lift . No HD cam chain for hyvo .....maybe replace with a new one..... :blink:
1985 GS 1150E
1983 GS 1100E
  • tommyboah
15 Jan 2014 14:14
#618752
turboking wrote: I'm not sure you will have to clearance , maybe a bit ,if any on the head or cover for the lobes with a .410 lift . No HD cam chain for hyvo .....maybe replace with a new one..... :blink:
I need to cleareance the valve covers for the lobes with the K410, checked with APE. I've talked to a Kawa-man i Norway and he told me that I should not change the cams, as I will have trouble with regards to using it as a street bike. I think I will just port the head instead and keep the stock cams for now...
.Tommyboy
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
15 Jan 2014 16:01
#618762
I wouldnt see any problems running 410 lift cams on the street. I run 418 lift cams on the street with no problem. The cams will change the power range. But they will make a increase in power espically with a ported head. i wouldnt see any problem running them.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
15 Jan 2014 16:13 - 15 Jan 2014 16:13
#618763
that doesn't make sense, sounds like bad advice to me.
that bike will run like a bull with that setup.
what is stock lift on that bike?
Last edit: 15 Jan 2014 16:13 by 4TheKZ1000.
