- Thank you received: 198
Top Oiler
- 4TheKZ1000
- Visitor
13 Jan 2014 14:16 #618460
by 4TheKZ1000
Top Oiler was created by 4TheKZ1000
Hello forum,
I would like to disable my factory oiling system to head and install a top oiler.
I would like some advice but do have a few questions.
Do they make a billet cross bar for the head as the Suzuki has? The different sections of hose doesn't look good for me.
How do you plug the oiling system, and where do you do it at.?
- peter1958
- Banned
13 Jan 2014 14:41 #618466
by peter1958
Replied by peter1958 on topic Top Oiler
The following user(s) said Thank You: 4TheKZ1000
- 4TheKZ1000
- Visitor
13 Jan 2014 14:48 #618468
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Top Oiler
Thanks mann......I remember this thread.
ZED is the freakin man .......
- Powerstroke_fan
- Thank you received: 83
13 Jan 2014 16:54 #618488
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Top Oiler
If you decide to do this. Be sure to keep us updated. Ive debated doing it someday.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- 4TheKZ1000
- Visitor
13 Jan 2014 17:05 #618490
by 4TheKZ1000
Ok
- peter1958
- Banned
13 Jan 2014 17:14 #618492
by peter1958
I have all the parts to do it. but have so many dam things im working on all the time. Some day I will take pictures
- Powerstroke_fan
13 Jan 2014 18:03 - 13 Jan 2014 18:04 #618498
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
I was consider doing it lines all the way. But i would like having a manifolds/rails for the head. They look a lot cleaner in my opinion. Then you gotta make a custom oil bypass, Then it gets a little more diffcult if your running a cooler also.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 13 Jan 2014 18:04 by Powerstroke_fan.
- 4TheKZ1000
- Visitor
13 Jan 2014 19:55 - 14 Jan 2014 07:27 #618513
by 4TheKZ1000
Attachment 837a449c2Df4782D401b2Db1622D3e231fe3eb85ProMo8.jpg not found
Attachment 92ec58eb2D52df2D41642Dbf7e2D5ef2542352depro3.jpg not found
Last edit: 14 Jan 2014 07:27 by 4TheKZ1000.
- racer54
- Thank you received: 114
13 Jan 2014 22:31 #618518
by racer54
Replied by racer54 on topic Top Oiler
To my knowledge there is no aftermarket version of a top oiler system for a stock kz or j head. Only for the billet heads.
- 4TheKZ1000
- Visitor
14 Jan 2014 05:40 #618529
by 4TheKZ1000
+1
racer54 wrote: To my knowledge there is no aftermarket version of a top oiler system for a stock kz or j head. Only for the billet heads.
+1
