2002 KZ1000P Exhaust- choices?
- ckamin
13 Jan 2014 12:30 #618448
by ckamin
2002 KZ1000P Exhaust- choices? was created by ckamin
Howdy! I recently purchased a '02 KZ1000P Police bike with only 22,000 miles on it. Love it (specially after changing the gearing to make it more freeway-friendly)! Are there any aftermarket choices for a replacement exhaust system? I like the stock system and I'm cleaning the bike up a bit, but a replacement stock system is really pricey. I saw MAC systems on ebay and I wonder if anybody has used them and can relay info on fit/finish. Also, are there any other options?
Thanks guys,
-Carl
(pictures to follow)
Thanks guys,
-Carl
- guitargeek
- Thank you received: 50
13 Jan 2014 12:36 - 13 Jan 2014 12:54 #618449
by guitargeek
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
Replied by guitargeek on topic 2002 KZ1000P Exhaust- choices?
I'm using my stock system, but not the mufflers. One of my stock mufflers rusted and fell off (before I got the bike). I bought a pair of Cherry Bombs and some adapters.
Eventually, I'll get this thing running and will post videos when I do...
Last edit: 13 Jan 2014 12:54 by guitargeek.
- ckamin
13 Jan 2014 12:55 #618450
by ckamin
Replied by ckamin on topic 2002 KZ1000P Exhaust- choices?
Cool! I am just looking for something that looks stock or is similar to stock.
- Cynjut
- Thank you received: 26
13 Jan 2014 14:35 #618464
by Cynjut
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
Replied by Cynjut on topic 2002 KZ1000P Exhaust- choices?
Stock for the "P" Model? or the KZ1000 in general?
The stock exhaust for the P model was a dual exhaust with a crossover under the transmission, much like the exhaust system above. Lots of the Z1000s you see have 'upgraded' to something a little more like the Kerker 4-into-1, a single can exhaust typically exiting on the right side of the bike. At this point in the life of the model, both end up looking pretty stock. With the exception of the color and a few profile nits, the Cherry Bombs aren't really that different than many common dual exhausts.
1977 KZ-1000 A1
- Thank you received: 1656
13 Jan 2014 15:48 - 13 Jan 2014 15:49 #618475
by martin_csr
Replied by martin_csr on topic 2002 KZ1000P Exhaust- choices?
No eBay APP ID and/or Cert ID defined in Kunena configurationmurqulza posted the following item in the ebbaayy-CL topic. I don't know what bikes the system fits, but the KZTooG the seller mentioned in the listing may indicate that it is for a 1000. To my eye it looks too big for a 650 or 750. If it's for an earlier 1000, I don't know if it would work on a late model Police bike w a J motor.
By murquiza: Found a nice exhaust in ebay. I already bought mine but someone might use this.
Last edit: 13 Jan 2014 15:49 by martin_csr.
