Cracked engine cases
  • greenman43
  • greenman43's Avatar Topic Author
13 Jan 2014 00:24
#618379
So, once again I’ve proven to myself that I’m a complete idiot. Whilst separating the cases on my Z1R engine, I surmised that they weren’t coming apart easily because of corrosion around the dowel pins, hence it was going to be simply a case of tightening down the three bolts more. Wrong. Oh so very wrong. I missed the bolt in the starter motor cavity, and as a result I now have a cracked lower crankcase … 
My own stupid fault quite obviously, but now I need to try and remedy it. I was originally looking to weld them up, but I’m now thinking that JB Weld should do the trick as I don’t believe it’s in an overly stressed area, and we are talking one of the 6mm bolts. However, the stress has distorted the area slightly, such that it’ll need to be pushed back into shape before trying to fix it.
Thinking that if I bolt the cases back together and then heat the area with a heat gun, the material should ‘soften’ enough to return to it’s original shape. Then I apply the JB Weld, let it set, and see how the cases look when I unbolt them. Wondering what the consensus is on this, am I naive in thinking the heat gun will heat the area enough for this to work and that JB Weld will hold, and do I just need to bite the bullet and get it welded ? Alternatively, it is going to be simpler to just buy another set of cases ?
For background, this will be a mostly-stock engine rebuild, and as its going into a Mk II chassis, originality re Z1R engine number is irrelevant to me. At the moment, I’m thoroughly discouraged with this build, and on the verge of putting the MK II aside to start on a GPz900R project waiting in the wings. I’m hoping for a cost-effective solution, to restore some enthusiasm !
Thanks in advance,
Brian
1980 Z1000 A4 Mk II
2007 ZX10R 'SL' (superlight)
1989 GPz900R
  • Puffin
  • Puffin's Avatar
Re: Cracked engine cases
13 Jan 2014 00:37
#618381
Dont mess around :ohmy: Get someone who knows what they are doing to Tig Weld it ;)
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
The following user(s) said Thank You: greenman43
  • Z1Driver
  • Z1Driver's Avatar
  • love the smell of triple smoke
13 Jan 2014 00:41
#618382
^^^^^^^^^^ + 1
Blue 1975 Z1B
Red 2009 Concours 14
  • ed spangler
  • ed spangler's Avatar
  • Tennessee Z
13 Jan 2014 03:23 - 13 Jan 2014 03:24
#618395
+2
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
Last edit: 13 Jan 2014 03:24 by ed spangler. Reason: hmm
  • sbc1320
  • sbc1320's Avatar
13 Jan 2014 05:44
#618400
As stated leave it to a professional. A heat gun will do nothing for it at all.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
13 Jan 2014 06:10
#618403
If all else fails, Call or e mail Joe Hooper at Pit stop. He advertises here and Im sure he can help you. I have had very good luck with his company for quality work and pricing
HTH
  • turboking
  • turboking's Avatar
13 Jan 2014 06:40
#618406
get it tig welded by a good competent welder :dry:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • baldy110
  • baldy110's Avatar
13 Jan 2014 10:10
#618428
DO NOT use JB weld, TIG it. I know it's the most difficult and expensive method but when it is done it wil lbe done for good. JB wled has it's purposes but in this case it would be a ghetto repair.
  • Cynjut
  • Cynjut's Avatar
13 Jan 2014 11:06
#618441
I disagree - JB Weld would be the most expensive repair.
It will look like it's working, then will fail, dumping your engine oil, probably at speed. If you get lucky and none of the oil pouring out of your engine gets on your tires, you'll seize a cam bearing, score a rod bearing, score your piston sleeves. burn out your rings, and probably cook the crank. After that, you'll still have to TIG weld it to fix it, but now you have to replace other engine components as well. The cheapest solution is to just fo it right the first time.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
13 Jan 2014 13:57
#618458
i made that same mistake once :sick: !
you will never forget that bolt again :whistle: .
i tigged it up and filed it back flat and it hasn't been an issue.
  • z1wiz
  • z1wiz's Avatar
13 Jan 2014 14:33
#618463
If you aren't worried about the case numbers, buy another set of cases. Probably cheaper than welding the cases you have.
Over 30 years with z1's, Currently down to only one 75, a j model dragbike, and 2 KZ1000 dragbikes.
13 Jan 2014 15:45 - 13 Jan 2014 15:46
#618474
Cynjut wrote: .....you'll still have to TIG weld it to fix it........ The cheapest solution is to just do it right the first time.
+1 Absolutely true! Ed
Last edit: 13 Jan 2014 15:46 by 650ed.
